Parting out top end of TPI motor
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
It really to much to list but Im parting out the whole top end of my 305 from heads to plenum..
hers a picture of the engine before I took it apart...make me some offers on what ever you want off of it and if Im selling it...
orted plenum
:Throttle body with air foil
:fuel rail with Holley AFPR and 19lbs injectors that have been flow matched by Rich @ cruisin preformance
:CAT 1.6 stamped steel roller rockers
:96 camaro LT1 Cam 203/210 477/480 @50 with 1.6's
:Runners
:intake with egr block off
:Brand new felpro 1010 head gaskets
:081 heads with LT1 valve springs
:3.23 gears
;10 bolt rear end brum brakes with 273 posi unit
:rocker covers
:brand new stock 6 3/4 balancer
:distributor with MSD cap
:whole AC unit working
:Stock LCA
:modified AC bracket for header install
:Stock torque arm
:spider tray that under intake on block
:SLP 1 5/8 tri-Y headers
:Brand new Comp Cam part#12-408-8... 206/212 480/487 @50 retro fit cam
:brand new advance water pump
:brand new Advance alternator
I'll let you guys have first dibs before it all goes to ebay.
I can take pictures of what ever it is you want to see..
thanks
orted plenum:Throttle body with air foil
:Runners
:3.23 gears
:rocker covers
:Stock LCA
:Stock torque arm
thanks
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
I don't know if you're willing to part out but...
Is that TB stock 48mm? Also looking for high performance cap & rotor. Prices / Pics? Thanks
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
Transmission: 700R4/Transgo
Axle/Gears: Stock Rear (3.27 gears)
In what condition are the heads, and how much for the 081 heads and roller rockers?
the rockers are 3/8 and are not self aligning
The heads are in I would say normal condition..they never gave me a bit of problems. ...
Heres a list I came up with...
just make me an offer if you want..
Throttle body with air foil = $100
:fuel rail with Holley AFPR and 19lbs injectors that have been flow matched by Rich @ cruisin preformance $150
:CAT 1.6 stamped steel roller rockers $50
:96 camaro LT1 Cam 203/210 477/480 @50 with 1.6's $25
:Runners $50
:intake with egr block off $100
:Brand new felpro 1010 head gaskets $50
:081 heads with LT1 valve springs $100
:3.23 gears $100
;10 bolt rear end brum brakes with 273 posi unit $200
:rocker covers $75
:brand new stock 6 3/4 balancer $50
:Stock distributor with MSD cap $50
:whole AC unit working $100
:Stock LCA $50
:modified AC bracket for header install $25
:Stock torque arm $25
:spider tray that under intake on block $25
:SLP 1 5/8 tri-Y headers $350
:Brand new Comp Cam part#12-408-8... 206/212 480/487 @50 retro fit cam $175
:brand new advance water pump $50
:brand new Advance alternator $50
:Runners $50
:3.23 gears $100
:rocker covers $75
:Stock LCA $50
if you need pictures let me know..
I will be going out of town on Friday and wont be back til late Sunday...
Throttle body with air foil = $100..SOLD
:fuel rail with Holley AFPR and 19lbs injectors that have been flow matched by Rich @ cruisin preformance $150..>SOLD
:CAT 1.6 stamped steel roller rockers $50..SOLD
:96 camaro LT1 Cam 203/210 477/480 @50 with 1.6's $25......SOLD
:Runners $50 ....SOLD
:intake with egr block off $100....SOLD
:Brand new felpro 1010 head gaskets $50...SOLD
:3.23 gears $100......SOLD
:rocker covers $75....SOLD
:brand new stock 6 3/4 balancer $50,,,,,SOLD
:whole AC unit working $100 ....SOLD
:Stock LCA $50
:spider tray that under intake on block $25....SOLD
:SLP 1 5/8 tri-Y headers $400
:Stock LCA $50
