tpi setup
Old Sep 29, 2006 | 11:44 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
tpi setup
I have pulled the tuned port setup off of my car. It has a BBK AFPR, holley air foil, freshly cleaned injectors, dizzy with accel cap and rotor, and an MSD blaster coil. One tube has some dents, but for 10 dollars you can buy them ***** on ebay. I have not planned on pulling the harness, but the ecu comes with it. Make offers. Thanks
Old Oct 1, 2006 | 09:32 PM
355gta's Avatar
Engine: 355
bump. someone out there needs this.
Old Oct 2, 2006 | 02:15 AM
355gta's Avatar
Engine: 355
I also have a cam that will work perfectly with the stock ecm. cammoton and tpis both said it was as big as you could go the the mass air ecm. it is a .458/.472 lift and 210/218 duration @ .050. it is brand new in the box. this should make a sweet motor. I run 13.9 last year with a stock tpi, just had the afpr, air foil, 2200 stall, and long tubes. that was on 225/50zr16 kumho 711 with 2.77 gears. i pulled a 1.87 60'. i think if i had the cam i could have went 13.5-13.7. make offers. thanks
Old Oct 2, 2006 | 01:08 PM
355gta's Avatar
Engine: 355
bump
Old Oct 2, 2006 | 04:12 PM
355gta's Avatar
Engine: 355
here are some pics.
Attached Thumbnails tpi setup-build-day-two-009.jpg   tpi setup-build-day-two-010.jpg
Old Oct 2, 2006 | 08:56 PM
355gta's Avatar
Engine: 355
if i do not sell this on here i will put it on ebay. i would rather sell it to someone on here. I will take 300 plus shipping for the whole thing with the cam.
Old Oct 3, 2006 | 12:32 AM
355gta's Avatar
Engine: 355
ttt
Old Oct 3, 2006 | 01:16 PM
355gta's Avatar
Engine: 355
bump
Old Oct 3, 2006 | 07:24 PM
355gta's Avatar
Engine: 355
bump
Old Oct 4, 2006 | 01:28 PM
Turbo6inKY's Avatar
Car: 1985 Pontiac Grand Prix
Engine: 5.7L TPI
Transmission: 200-4R
Axle/Gears: 7.5" 3.73 LSD
You have a PM
Old Oct 4, 2006 | 09:22 PM
355gta's Avatar
Engine: 355
bump
Old Oct 9, 2006 | 09:15 PM
Turbo6inKY's Avatar
Engine: 5.7L TPI
Sold! I have the TPI. Good word for 355gta. Everything was as described. Somebody buy the cam from him.
Old Oct 9, 2006 | 10:36 PM
355gta's Avatar
Engine: 355
thanks. is was nice doin business with you. i will check on the block tomorrow.
Old Oct 10, 2006 | 05:54 AM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
are the heads for sale possibly? i think i need new heads :S castin #081 i think:S
Old Oct 10, 2006 | 05:57 PM
355gta's Avatar
Engine: 355
the long block is gone. all i have left is a new cam and a 36mm sway bar.
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
