Parting out H/C 406 SBC
Old Oct 14, 2006 | 06:59 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
Im looking to sell parts off my motor or sell the whole thing at once
2 bolt main 406 SBC hypertec pistons(9.6:1 w/ 70cc heads)
stock length rods w/ ARP bolts
Sealed power rings and bearings-$700
Edelbrock RPM 70cc heads-$750
1.6 stamped steel rockers-$40
Crane Retro-fit roller cam+lifters 222/230 509/528-$500
Hardened pushrods-$60
Edelbrock RPM air gap intake(10 miles) -$170
Holley 850 Double pumper(10 miles) w/holley brushed alum fuel line.-$450
Mallory Adjustable fuel pressure regulator(10 miles)-$60 shipped
Earls Fittings-depending on if you buy the reg+carb.
accell u Gruve header plugs. colder heat range-$15 shipped
Earls Header gaskets with replacement centers(have replacements but not sure if i have all)-$20shipped
Let me know if you need any of this stuff. if you want it all save yourself $400 and ill sell it all for $2400
Old Oct 15, 2006 | 03:31 PM
Car: 85 Camaro Z-28
Engine: 6.6
nobody wants these parts???
Old Oct 15, 2006 | 05:35 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
im interested in some things, but probably not going to be shopping till spring, but i am located in south glens falls, ny, less than 2 hours south of you,
if you still have the stuff in a few months get back to me or leave me your email. thanks, keith
kburch5647@yahoo.com
Old Oct 18, 2006 | 04:17 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
$50 shipped to 49250 for the Mallory fuel pressure regulator? Need one by the 27th so........?????????
Old Oct 18, 2006 | 04:25 PM
Car: 85 Camaro Z-28
Engine: 6.6
im pretty set on the price of the FPR
Old Oct 22, 2006 | 12:35 PM
SmallBlockMaro's Avatar
Car: 1990 chevy camaro rs
Engine: 415small block
Transmission: th350
Axle/Gears: 373 gears
fuel pressaure regulater
is the fpr a bypass style...i need 1 for my camaro because i went from fi to carb and using stock pump....whats the part number on it and i will give you $60 for if its what i need..thanks
Old Oct 22, 2006 | 12:49 PM
Car: 85 Camaro Z-28
Engine: 6.6
it is what you need, im using the stock FI pump in the tank and this regulated it down to 5-6psi and it is the bypass type. part number 4309
Old Oct 22, 2006 | 08:14 PM
Transmission: th350
ok...thanks i want it....will you take a money order? send me your info on my email address which is smallblockmaro@aol.com....so i could send it to you
Old Oct 22, 2006 | 08:18 PM
Car: 85 Camaro Z-28
Engine: 6.6
E-mailed you.
make me some kind of offers on the other parts guys i need to get rid of this stuff!
Old Nov 3, 2006 | 10:13 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
What size are the runners on the heads. I only found RPMs with 170cc runners and 70cc chambers, but that seems way small for a 406?
Thanks,
Dan
Old Nov 4, 2006 | 06:33 AM
Car: 85 Camaro Z-28
Engine: 6.6
thats what they are. 170cc they seemed to work fairly well on my car.
Old Nov 4, 2006 | 08:11 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
andrew,
what kinda deal can we work on the carb, im throwing options on going to a 850 on my 406
Old Nov 5, 2006 | 03:35 PM
Car: 85 Camaro Z-28
Engine: 6.6
it depends if you want the other stuff. like fuel rail ect? im sure we can work something out
Old Nov 6, 2006 | 08:47 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
im mechanical fuel pump so that other stuff is kinda useless to me, i have a big problem with my demon im using at the moment... so i just am throwing around buying another carb....
Old Nov 6, 2006 | 12:41 PM
Car: 85 Camaro Z-28
Engine: 6.6
yeah well you still need a fuel rail unless you can use the one off of your demon. just basically let me know if you want the carburetor only.
Old Nov 6, 2006 | 10:25 PM
Car: 85 Camaro Z-28
Engine: 6.6
COME ON GUYS I NEED TO MOVE THESE PARTS!!!
Old Nov 7, 2006 | 01:12 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
If you werent 7 hours away i would be interested in most of this stuff, but i guess shipping might be an option? Is the engine assembled? How many miles are on it? Do you have any rebuild reciepts or anything? I am basically looking for an engine... I wouldnt need the intake or carb since i have both of those already... Why are you parting this engine out?
Old Nov 7, 2006 | 07:38 AM
Car: 85 Camaro Z-28
Engine: 6.6
i figured if i part the motor out it would sell quicker. but i have alot of receipts but i dont know if i have all of them... id have to dig through them. there is about 10-12k miles on the motor.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
