8-306-8
Old Oct 21, 2006 | 02:59 PM
ssean92's Avatar
Car: sold
8-306-8
this is the comp cam that i got for my lt1 and come to find out it is for a non- lt1 engine. so if anyone out there has a rollor engine that is not a lt1 and need a great cam let me know.
here are the specs on the cam
Power Band is 2000-6000 RPM. The grind number is CS 290HR-12. The lifts are .510 In and .540 Ex with a 1.5 ratio rocker. The durations at .050 are 230 In and 244 Ex. Lobe separtion angle is 112 degrees. Timing event specs at .050 tappet lift are as follows; Int opens at 5 deg BTDC and closes at 45 deg ABDC, Exh opens at 56 deg BBDC and closes at 8 deg ATDC. These specs are for a 110 deg intake center line. Cam is ground on a standard base circle
ssean72@yahoo.com
looking for 150+ shipping for the cam but will take offers
Old Oct 21, 2006 | 04:42 PM
ssean92's Avatar
Car: sold
ttt
Old Oct 21, 2006 | 06:45 PM
ssean92's Avatar
Car: sold
price changed
Old Oct 21, 2006 | 10:52 PM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Sorry to hear Sean. Why isnt it for LT1?
Old Oct 22, 2006 | 08:49 AM
ssean92's Avatar
Car: sold
it is a 8 instead of a 7 dont have the previsions for the opti. been trying to find the 8-306# in the books and cant find it. so i am not sure know
Old Oct 22, 2006 | 11:14 AM
jimlt4383's Avatar
all you have to do is change the pin. you can get the long pin from comp cheep and most machine shops have a dowl pin puller.
Old Oct 22, 2006 | 12:56 PM
ssean92's Avatar
Car: sold
this also doesnot have the big hole in the center of the cam. has the small hole for the non opti spark engines
Old Oct 24, 2006 | 03:45 PM
ssean92's Avatar
Car: sold
well it is on ebay
SDC
Dec 27, 2001 10:34 PM
