New 350 shortblock ready to for heads!!!!
Old Nov 6, 2006 | 09:58 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
UPDATE!!!!! PICS ARE IN LOWER POST!!!!!!!!
1978 350 4-bolt main 010 block
.060 over zero decked
clearanced for 383 stroker
hyper 4-valve releif flattop pistons
chromemoly rings
GM crank
GM vortec 5.7 rods
Double row timing chain
HV melling oil pump
clevite rod/main bearings
292h 501/501 flattappet cam/lifters
oil pan
timing cover
balancer
flexplate
Fresh build, never run, ready for your choice of heads!!!!! $850
Old Nov 6, 2006 | 10:05 AM
dmason's Avatar
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
Hey bluegrassz, how happy are you with your current setup? I am planning to build almost the exact same combo. Going to use the new 195 eliminators though. Why are you using the holley instead of your demon?
Old Nov 6, 2006 | 10:11 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I am very satisfied with my combo. There is more in it, tires just cant handle it. lol. I plan on doing either a 355 or 383 later on. I will work the heads and intake a little more. And go with a larger hyd-roller cam or a solid roller cam. Right now the car is a strong street car. I should be in the low 12's come spring with better tires, carb, and good air.
The holley I have has some alterations to it and works fairly well. I do however plan on selling both carbs and going to a Holley HP.
Money has been sent for the Demon, Looks like the holley will be up for sale also.
Old Nov 7, 2006 | 07:40 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Selling this for a friend.
bump
Old Nov 8, 2006 | 08:37 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
BUMP!!!!!
Friends trying to pay his radiation treatment bills.
Hes 34 year old and had to have some cancer removed.
Its a good build. Rods/block/crank was all checked at the machine shop before build. All the clearances have been double/triple checked.
Just a good set of heads and intake and it will be a strong runner.
Old Nov 13, 2006 | 07:30 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
BUMP!!!!!!!!!!!
He is getting pics of the motor and I should have them posted in the next few days.
Old Nov 15, 2006 | 02:07 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
TTT
Old Nov 20, 2006 | 10:56 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Here are some pics of the motor!!!
Attached Thumbnails New 350 shortblock ready to for heads!!!!-pimage008_001.jpg   New 350 shortblock ready to for heads!!!!-pimage009_002.jpg   New 350 shortblock ready to for heads!!!!-pimage010_003.jpg
Old Nov 20, 2006 | 10:57 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
a few more
Attached Thumbnails New 350 shortblock ready to for heads!!!!-pimage011_004.jpg   New 350 shortblock ready to for heads!!!!-pimage012_005.jpg   New 350 shortblock ready to for heads!!!!-pimage013_006.jpg
Old Nov 21, 2006 | 07:22 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
This would be a real good shortblock to put your heads and intake onto.
My friend had the motor built an needs to pay some of his doctor bills.
We can ship if anyone wanted to pay for the shipping. Its located in KY just a few miles of Interstate 75. Very easy to find. May be willing to deliver within so many miles, or meet half way.
Old Nov 23, 2006 | 09:04 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
HAPPY THANKSGIVING BUMP!!!!!!
Old Nov 23, 2006 | 09:21 PM
eds67's Avatar
is it a 383 or 355? be interested in a 427 needs rebuilt and cash?
Old Nov 24, 2006 | 10:47 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
He had built it up as a 388. He decided to build a 408 and used the crank and rods out of this block. So the block is clearanced for a stroker crank. It is bored .060 over and has a stock 3.48 stroke 350 crank in it. Which means it is now a .060 over 350. The crank, rods and block have all been checked. The pistons/cam/lifter/bearings/rings are all new.
I dont think he would want to trade on the 427, but I can ask him.
Were are you located at?
Old Nov 27, 2006 | 07:16 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Let me know more about the 427. Is it out of a car or is it a tall deck block out of a truck? What is wrong with it?
Also were are you and the motor at?
Old Nov 27, 2006 | 03:58 PM
eds67's Avatar
sorry i just sold it
Old Nov 30, 2006 | 08:09 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
TTT
Old Nov 30, 2006 | 11:11 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
should be a 360ci as it stands.
do you happen to know what the wall thickness is on the thrust side of each cylinder? .60 is quite an overbore for some blocks.
~Nick~
Old Nov 30, 2006 | 11:46 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
~Nick~
Yeap, you got it 360!
I can check the thickness. He had ran the motor with no problems at all. He went to a 408 is the only reason he is not using the block.
Oh yeah, The center line on the block is centered. Sometimes you can notice core shift in some blocks, but this one is dead on. Definatly a plus with it bored 60 over.
Old Dec 1, 2006 | 10:28 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
~Nick~
I cant find any numbers on the thickness, and the oil pan is already on.
He ran it as a 388 with no problem.
Old Dec 1, 2006 | 11:47 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
My budget is $600. I am looking for a good shortblock for my Chevy truck. I wouldn't need the cam. I am about 4 hours away from there in WV. Not trying to bring your price down but if he can't find a buyer my offer stands.
Old Dec 1, 2006 | 01:00 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
He said he couldnt go $600 sorry.
Old Dec 4, 2006 | 08:08 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
bump
Old Dec 7, 2006 | 01:28 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Dosent someone need a good shortblock with zero miles on it????
Old Dec 11, 2006 | 11:40 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Would be a nice christmas gift!!!!!
Old Dec 28, 2006 | 04:58 PM
hotrodhaskins's Avatar
Car: 1988 pontiac firebird
Engine: 332sbc
Transmission: th350
Axle/Gears: 10bolt 28 spline posi trac 3.73 gea
how well was it ballenced and is it a 010 020 bllock or not
Old Dec 29, 2006 | 09:51 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
how far are you away from indianapolis?
Old Dec 30, 2006 | 09:29 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
you have a pm
Frozer!!!
Jan 19, 2024 04:55 PM
CRFred
Feb 7, 2016 11:39 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
