worked 3.4 v6 heads and LIM, t5, spec clutch and flywheel
Old Dec 1, 2006 | 06:35 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
New 3.4 iron heads about 3k miles on them. gasket matched/mild P&P/shaved .030"-200.00 for the pair(190.00 each new plus 90 for having them shaved)
Lower intake manifold-gasket matched-mild porting-machined to new angle to match .030" shaved heads(190.00 job )---75.00
I have a BORG WARNER T5 non world class----it was rebuilt some time ago, but it is in need of another one soon, it whines once in a while going into gear while down shifting...has a new 1-2 shift fork, a poly mount... also have a stock shifter that has been shortened and has a adjustable 2nd gear stop welded on. the b&m leather **** is epoxied on....
1991 3.1 camaro flywheel( for internally balanced engines) and a spec stage 1 clutch with 2500mi, 30 for the flywheel and 50 for the clutch
Well, this list is getting long.anything you want off the car aside from suspention/body/rear end/wheels/tires....you can have it
Old Jan 17, 2007 | 02:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I need a flywheel for 3.1 91 V6 and a T5 Transnission. If you still have it - let ma know ASAP !
grngryoutmyway
Oct 18, 2016 05:48 PM
PurelyPMD
May 5, 2016 04:57 PM
customblackbird
Oct 1, 2015 04:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
