Posi rearends
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Posi rearends
3.27/posi 9-bolt w/PBR disc ('89 Formula)--- $350
2.77/posi 9-bolt w/PBR disc ('89 IROC)--- $250
Both disc rearends come complete with rotors, calipers, master cylinder, prop. valve, rear sway bar, and e-brake cables.
3.23/posi drum rearend complete drum to drum --- $200
All three rearends are in excellent working condition. Pick up only, I'm located about 40 minutes south of Chicago.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Dang...didn't they put 9-bolts in cars destined for the Southwest? Wish you were closer.
Car: 1988 Chevrolet Camaro SPL
Engine: 350 Modified
Transmission: T-5 manual
Axle/Gears: Ford 9in - 3.50
You have some real good deals.. ever come closer to Michigan? I'm in the Detroit area.. and 4 hours is a pretty long haul..
The 3.23/drum 10 bolt is sold. Here's what I have right now:
3.27/posi 9-bolt w/PBR disc ('89 Formula 350) --- $350
2.77/posi 9-bolt w/PBR disc ('87 IROC) --- $250
2.77/posi 9-bolt w/iron caliper disc ('86 Trans Am) --- $200
I can ship them DHL freight collect if you want. You will pay me for just the rearend and DHL will bill you for shipping once the item is delivered.
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
How much would freight run? I went on DHL's website and could find nothing on a freight service or quote. I estimated it weighs about 250 lbs and is 2ft x 6.5ft x 2ft
KO1
16
Oct 15, 2015 05:00 PM
I have been trying to find a 9bolt near me... goodluck with the sale.
