LT1 style T56 swap kit
Old Mar 15, 2007 | 07:02 PM
Badmire68's Avatar
This is a 95 model T56 with 77K miles on it. comes with Clutch(worn), pressure plate, flywheel, bellhousing, SLP billet shifter, pedel assembly, and crossmember. $1200 firm
<a href="http://rides.webshots.com/photo/2421704270071934684XANqKX"><img src="http://thumb4.webshots.net/t/16/17/7/4/27/2421704270071934684XANqKX_th.jpg" alt="T56 swap kit"></a>
Old Mar 23, 2007 | 06:27 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: LT1 style T56 swap kit
Would you ship? How much to ship it to 74006?
Cheers,
Richard.
Old Mar 23, 2007 | 10:27 PM
Badmire68's Avatar
I can put everything on a pallet strapped and ready to go. You will have to set up the shipping with a trucking company though and schedule the pickup. I have a loading dock at work that will make it cheaper and easier for a company to come pick up. if your interested. send me a e-mail to Badmire68@bellsouth.net
Old Mar 25, 2007 | 08:26 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
I would only really be interested if you could organise the shipping..
Cheers,
Richard.
Old Mar 25, 2007 | 10:09 PM
Badmire68's Avatar
I could organize the shipping. Is there a business I can ship it to? If not most shipping companies will want you to pick it up at the terminal or the will charge a big fee. Send me an e-mail to the address I listed above if you are serious and want me to get some quotes.
Old Mar 26, 2007 | 12:05 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
damn, your just too far away for me.. 7 zones!
Old Mar 26, 2007 | 08:08 AM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Would i be able to use those pedals on my third gen? Does it come with all the boots for the shifter and the hydraulics and fork for the clutch?
Old Mar 26, 2007 | 03:36 PM
Badmire68's Avatar
I'm not sure about those pedels. You will have to do some research. it doesn't come with a boot or the hydralics. it does come with the clutch fork.
Old Mar 26, 2007 | 08:18 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
hey guys i just did that exact same swap on my 89 iroc and yes those pedals will work. the onl difference is that the 3rd gen cars have a 2 piece pedal set up and the 4th gen setup is a one piece set up. kind of a bitch to put the in but with some elbow gease you can get them to fall in place
Old Mar 29, 2007 | 11:51 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Pic looks good. Is the crossmember for 3rd or 4th gen? Very interested.
Old Mar 31, 2007 | 12:55 AM
net_coma's Avatar
You need these pedals for a thirdgen swap, thirgen pedals don't have the proper angles for clutch operation.
Old Mar 31, 2007 | 05:54 AM
Stevo's Avatar
Car: Pair of 92 Z28s
You will want to hack off the gas pedal off the 4th gen pedals, no sense in leaving it attached everything you do to swap the T56 over you dont need to touch the stock gas pedal. You will also have to enlarge i think 2 of the mounting bolts cant remember if it was just 2 or all of them. I wasnt able to use third gen clutch pedals because of the master cylinder rod wouldnt attach to the pivet on the pedal. Not sure if it matters on stock 82-02 hydraulics.
Free Bump for a good deal.
I got mine for $1400 local 47k miles but that was with a $1000 clutch setup. Spent another easy $300 on other parts.
Old Apr 29, 2007 | 03:00 PM
SARswmr's Avatar
PM sent.....
Old Apr 29, 2007 | 08:57 PM
Badmire68's Avatar
sold
1984HO
Mar 19, 2021 11:59 AM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
