Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)
Subscribe
Mar 20, 2007 | 11:33 PM
Spohn Torque Arm Chrome Moly w/ Loop for 700R4. It was $560 new as shown in attached image from spohn.net. Modifed/Relocated driveshaft loop mount (not loop itself) upward about 1" to aid mufflex exhaust clearance. Will take $365 + shipping.
Barely used high output 200 amp serpantine alternator for biggg stereos. $80 + shipping.
Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-torque-arm.jpg
Reply 0
Mar 21, 2007 | 09:14 AM
Re: Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)
does this mount to the trans or crossmember? what mufflex exhuast piece did you need to get around? y-pipe?
Reply 0
Mar 21, 2007 | 10:46 AM
The torque arm package consists of a special crossmember (included) with driveshaft loop (included) and the spohn torque arm itself (included) . The load of the torque arm is transmitted directly to the crossmember instead of the factory method of transmitting the load to the trans tail shaft.
Yes, the mufflex ypipe for long tube headers and 4" catback.
Reply 0
Mar 21, 2007 | 03:35 PM
OK, just to confirm. I have the hooker long tubes 2210s & a mufflex off road Y-pipe. Will the this set-up fit my car? Did you do the modification? last time I talked to Spohn they said that they didn't make a torque arm that would fit my set-up.
Reply 0
Mar 21, 2007 | 04:49 PM
second in line. you got PM.
Reply 0
Mar 21, 2007 | 04:51 PM
The mufflex y-pipe will not bolt up directly as-received from mufflex. Some modification of the mufflex y-pipe were necessary before it could be used with this torque arm system. Unfortunately, I dont have any pictures of the final installation to be more descriptive about how I pulled it off. It was not easy, but it can be done. If I were to do a thirdgen all over again, I'd use this torque arm and custom fabricate an oval y-pipe from dr. gas oval bends.
Reply 0
Mar 21, 2007 | 05:58 PM
Well I'm going to have to think about this. I already have the LT's & Y-pipe installed. If someone else is interested go ahead and take me out of line. thanks for all the input though.
Reply 0
Mar 21, 2007 | 08:28 PM
do you have a part numbe ron the alternator? who was it orig made by?
Reply 0
Mar 21, 2007 | 09:03 PM
I bought it from DB Electrical. You can contact them at dbelectrical@comcast.net or call at 800-753-2242. I'm sorry but I do not know the part number. It is not a single wire alternator...it is set up for factory wiring (thirdgen 90-92 serp systems). With the factory alternator, I had constant charging problems. I had a ton of electronics running in the car (DFI, laptop, wideband, gages, two amplifiers, etc). This thing solved my problems for good! Remember to use a 4 ga. wire to the battery from the output post. It's output is 105 amps at idle, but it lights up like mad above idle. It does not have the iceberg aft housing, but I have never have had any heat/charging problems with it.
Reply 0
Mar 24, 2007 | 12:53 PM
Still available! Here are the pictures as promised...
Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-p3241130.jpg   Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-p3241131.jpg   Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-p3241132.jpg
Reply 0
Mar 24, 2007 | 12:54 PM
And more...
Spohn extreme duty driveshaft also for sale make offer
Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-p3241133.jpg   Spohn Torque Arm w/ Loop for 700R4, Barely used high output alt (big stereos)-p3241134.jpg
Reply 0
Mar 24, 2007 | 01:53 PM
How much to ship the alternator to 29063? Can you ship it in a USPS one-rate box? I'm very interested. Thanks.
Reply 0
Mar 25, 2007 | 12:33 AM
Let's say 10 bucks for shipping the alt
Reply 0
Mar 25, 2007 | 12:37 PM
Consider the alternator sold then. PM me with payment specifics. Thanks.
Reply 0
Mar 25, 2007 | 10:46 PM
Jade bought the alternator, but Spohn Torque Arm and Spohn Driveshaft still left!
Reply 0
Mar 31, 2007 | 08:21 PM
Received the M.O. today for the alt- will ship it moday..thanks!
BUMP Torque Arm and Driveshaft still available!
Reply 0
Mar 31, 2007 | 09:13 PM
Thanks for the update! I should have PMed you the day I mailed it. Anyways here's a free bump.
Reply 0
Apr 1, 2007 | 03:08 AM
How much you think it would be to ship that T/A to 60126?
Reply 0
Apr 6, 2007 | 06:09 PM
Woops sorry, I changed my email address and didn't get notified of your reply. I think the torque arm will cost about 50 to ship to most of the cont. us. Shipping prices have really gone up lately..ugg. Keep in mind, you'll have to pay to ship it from Spohn too....
Reply 0
Apr 13, 2007 | 10:30 PM
Do you think this would still bolt on to car with a 3in factory routed exhaust with out having to remodife the loop. Will this fit a borg 9 bolt housing?
Reply 0
Apr 13, 2007 | 10:58 PM
Absolutely! It will fit with any exhaust that runs the stock routing! Also, it will fit your 9 bolt and any 10 bolt or a moser 9".
Reply 0
Apr 16, 2007 | 12:28 PM
How much do you want for the driveshaft shipped to CT? As long as it is vibration and ding free I am interested. Is it mild steel or cromoly? Approximate weight and torque capabilities? Thanks.
Reply 0
Apr 16, 2007 | 02:37 PM
I'm sorry, but the driveshaft sold last weekend.
I still have the Torque Arm for sale though!!
Reply 0
Apr 16, 2007 | 03:52 PM
that's too bad, I have the spohn t-56 crosmember and torque arm combo already, other wise I'd be on this one. Out of curiosity what did the dshaft go for?
Reply 0
Apr 16, 2007 | 08:24 PM
I had $500 into the driveshaft and sold it to a friend locally for $150.
Reply 0
Subscribe
