FS: 383short block,eibach's, agx's, sfc's, cams, and more
I've abandoned my third gen project and moved back to a 4th gen LS1 so this stuffs gotta go!!! All prices are somewhat negotiable, no low ballers please
- I've got a 383 stroker short block that was built from the original roller 350 outta my 89' GTA. It has a maximum of 5K miles on it. It has an Eagle steel crank, GM 5.7" "stage 2" Rods, and Forged Pistons. The rotating assembly was purchased from Speed-O-Motive back a few years ago. It was prof. assembled and balanced by Weimer Machine in Berwyn IL. However despite my efforts to keep it oiled over the last year of sitting it has developed a small amount of light rust in the cylinder walls. Nothing a quick hone job can't take care of, which I may do before it sells. PM me with any questions. I am looking to get $600 for the short block. this will have to be a local pick up item only, sorry.The engine is SOLD
- I also have a 700R4 trans with less then 5K miles on a fresh rebuild. I know it had a corvette servo installed at the time of rebuild and probably a shift kit but cannot not recall. SOLD
- Crane cams 2032 hyd. Roller camshaft. Great cam for stock or modified TPI cars. used less than 5K miles. Still looks new. $160 shipped
- Comp cams XR294HR Hyd. Roller camshaft. Duration @ .050 in.242/exh.248 lift in 540"/exh 562" on a 110 LSA, never got to use this cam, but was told it only had dyno time on it. Also still looks new SOLD
- Kevko 7qt oil Pan with oil pickup part # 1070NRH for sbc. Never used, only opened box for pics. New was $169 sell for $120 shipped
- Crane Cams High-Rev kit, great item to have to help reduce dreaded valve float. $60 shipped
-165 ECU for MAF cars. $65 shipped
- I have 2 Tq converters one is supposed to be a 2500RPM stall and the other 3000 RPM stall. I have not used either one of these so i cannot verify there performance. They do not have any markings on them to suggest who made them. Asking $60 each, prefer pick up these as they're pretty heavy and may not be worth shipping. Both converters SOLD
- Full set of KYB AGX adjustable shocks and struts new in boxes. $320 shipped
- Set of Eibach Pro kit springs. I can't remember how many miles are on them, I bought them used but never took them outta the box. They look unused and very well could be. $150 shipped SOLD
- Set of CGS brand Subframe connectors bolt-in/weld in style. Still new in the box. $130 shipped SOLD
I probably have more stuff that I have forgotten about, and will update this as I find it. thanks for looking.
Located in the Chicago Suburbs, feel free to PM me with any questions or if you need pics of anything.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: FS: 383short block,eibach's, agx's, sfc's, cams, and more
[QUOTE=
.[/QUOTE]
what is this part? ignition coil, rev limiter? also do you have a pic of it. and could you get a shipping quote to 68113?
.[/QUOTE]
the rev kit attatches to your cylinder heads to keep extra pressure on your lifters. Pm me with an email address and i'll send you some pics.
Formula350: the SubFrames are the only item I do not have pics of yet. Sorry, I'll try and get some ASAP
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
oll man thanks maybe tuesday I can run out by you and look at them ....... What brand are they?
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
PM sent about 383, 700, and a converter. Hoping to see pics. Thanks.
Car: 1986 Z28
Engine: 406
Transmission: TH350
Axle/Gears: 9-inch w/ 3.50 posi
PM sent on rev kit and oil pan. Hope to see some pics.
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
Vey interested in the springs. would like some pics to bobbyss23@aol.com. Where are you located in chicago?
PM'd you
PM'd you
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Any word on the 2500 converter? Still intrested
Car: 1988 Trans Am GTA
Transmission: 700r4 rebuild, heavy duty clutch pa
springs still for sale? If so let me know
Car: 1985 camaro iroc-z
Engine: 350 4 brrl
Transmission: B&W T5
Axle/Gears: B&W 9 bolt 3.45
interested in any pics of sfc's what brand are they. how much to ship to P1L 1X4 canada. thanks
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
may be interested in sfc's if they will fit on a vert. do you still have the springs?
There is a sale pending on the springs, I'll let you know if it falls through, thanks
SFC's will not fit Verts, sorry.
Engine: 305 TBI LO3
sounds good. do you know if those sfc's will work on my car?
Update: SFC's and 2500 Stall are SOLD
Eibach Springs are SOLD
On Probation
Car: 1992 Pontaic Firebird
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
how much for the shocks and struts shipped to 12019, ny please? r they for a v8 ?
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
darn, when will i ever get my car up and running. I really needed that 383 and would of paid more money for the gmoney man
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Please email pics of the rev kid to theronmaull@yahoo.com -- I'm building a 302 and could use it
Tyler
Tyler
Tyler
Tyler
Car: 89 Formula
Hey man you got thoes rims you said you may have if so i'm interested
Car: 89 Formula
gixxer92
Sep 1, 2015 04:32 PM
