Need to get this stuff moved out. You want it, right?
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
USED> Fuel Rail. 86 fuel rail with 9th injector. No pressure regulator. Rails are in great condition tubes are OK. $40 plus shipping.
USED> Stock GM lower TPI base and runners for 87 and up without 9th injector hole. Mildly ported. Base is red and runners are unpolished aluminum. $90 for both.
USED> Pro Comp Billet distributor #10001. Used for about 2 years and 4000 or so miles. Also comes with an Accel Electronic coil #140008. The coil was used for about 4 years. Coil was painted black to try and hide it better. $155 shipped. http://procompelectronics.com/Files/5.html
USED> Selling for a friend. MSD distributor from a 305 TBI car now 383. Very little use 1.5 years old. Works great. $175
NEW> One oil pump pickup screen for small block chevy with a stock oil pan. Slip on style. $5
USED> One K&N Filtercharger. Came from a TBI camaro. I believe it is part number #E-1450. Measures roughly 12" round and 2 1/2" thick. Looks brand new, oiled and ready to go. $25 shipped. Check fitment first. Should fit any round camaro stock air cleaner from 1976-1992
USED> One K&N Filter charger for a Camaro or Firebird with any engine built from 98-2002. It is in great shape with no problems , oiled and ready to go. $38 shipped. Part number 33-2118 Retails for $58
USED> Stock steel driveshaft from 700R4 car. May need rebalancing and possibly u-joints. Otherwise looks good with not dents. $25
USED> One Carter Competition AFB Carb. 600 cfm. Part number 9605s. Still shiney should work perfect. Similar to Edelbrock. $110
NEW> Throttle Body bolts. Three sets of cap head/allen head bolt sets for throttle body to plenum mounting. Two sets are stainless steel and one set is black. $10 shipped for each
NEW> Throttle body lever arm for older 86-89 throttle bodies. Zinc coated. $25 shipped
NEW> Holley Stealth Ram fuel crossover tube. Never used excellent shape. $20 shipped
I have some othser stuff here: https://www.thirdgen.org/forums/post...365-post9.html
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need to get this stuff moved out. You want it, right?
"MSD distributor from a 305"
MSD Part # ?
MSD Part # ?
OK,
The part number I was given is for a pro billet MSD distributor with a number 8366 on the housing.
Here is the Summitracing.com link to the distributor.
http://store.summitracing.com/partde...5&autoview=sku
The price again is $175 plus shipping. It is not negoatiable. Down anyway.
Let me know who really wants it. I can get shipping quotes if you want them or you can opt to go with a rough guess of $20 to anywhere in the continent.
I was told that this dist. was used for about 2300 miles and about a year or so. The car was used mostly to go to the local cruise and maybe down the strip once or twice. It's nice and clean. The guy switched to carb and vacume advanced MSD.
I also have another brand billet distributor with Cap and Rotor and an Accel electronic coil for sale. The distributor is about 2 years old with maybe 4000 miles on it. The coil is probably 3 years old with a little more miles. The coil was painted black to try and hide it. You can have both for $155 shipped.
PM me for Pay Pal ID.
I forgot to add this one.
Hi
Hi can i get pics of the MSD distributor please ? please send pics to pmccall@adelphia.net thanks...
Pics will be difficult due to the fact that I am not in possesion of the MSD distributor. It is at my friends house and he lives about 30min from me and has no digital camera or even an internet connection. So for now I can't but I will try and get him to bring it next time we go to the local cruise. Besides if you've seen one MSD distributor you've seen them all!!!
Alright,
I need to get this stuff moving so I can get some other parts for my new 92 T/A convertible project car. I will DEFINATELY consider trades for parts on the 92. I need most front end body parts and things like black front carpet and dash pad and such. Please just let me know what you have and what you want. I like to deal.
Sorry. Shipping would be close to $9 to Wis. That leaves me with around $5 after Pay Pal and such.
TheTraut88
Sep 7, 2015 05:22 PM
