FS: ARP 7/16" rocker studs and Comp 5/16" guideplates
Old Jun 29, 2007 | 01:34 PM
Camaroz29's Avatar
Asking 75$.
Old Jul 5, 2007 | 07:43 PM
Camaroz29's Avatar
Re: FS: ARP 7/16" rocker studs and Comp 5/16" guideplates
TTMT
Old Jul 9, 2007 | 06:29 PM
Camaroz29's Avatar
To the top.
Old Jul 10, 2007 | 01:22 PM
Iroc You's Avatar
will you seperate them i just need the studs i want to run adj. guide plates...thanks
Old Jul 10, 2007 | 05:14 PM
Camaroz29's Avatar
Sure, make an offer. The studs are new I hand threaded them into the heads to mock up the guideplates once and that is it. They have never been torqued.
Old Jul 10, 2007 | 10:44 PM
Iroc You's Avatar
which arp's are they el cheap o's or pro series?
Old Jul 11, 2007 | 09:11 AM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I may be interested in the guideplates. Pm sent
Old Jul 11, 2007 | 05:15 PM
Camaroz29's Avatar
I would guess "el cheapos" since the part that screws into the head is still 3/8". Pro series would be 7/16 all the way through I'd assume?
Old Jul 11, 2007 | 05:21 PM
Iroc You's Avatar
naw it has to do with the process arp makes them with...pro series are about 65 bucks!
Old Jul 11, 2007 | 05:52 PM
Camaroz29's Avatar
All they say on them is "ARP". Comp sells ARP studs as their own, and these came in Comp Cams packaging. I paid just over 80 for the studs and guideplates together (got them from the guy that did my TFS heads) so I couldn't tell you one way or the other.
Old Jul 12, 2007 | 02:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Something wrong there , all SBC studs have a base stud size of 7/16 (where it screws in the head); the thread for the rocker is either 3/8 or 7/16
Check out # ARP-134-7101 at Summit
Old Jul 12, 2007 | 07:45 PM
Camaroz29's Avatar
Call me stupid then. For some reason the bottom half looks "thinner" than the top half to me.
Old Jul 12, 2007 | 09:41 PM
Iroc You's Avatar
humm...not sure about that one
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
