CASPERS TPS ENHANCER #102015 TPI CARS
Old 11-06-2007, 08:34 PM
smallblockking's Avatar
TPS-TEC G57C
TPS voltage at Wide-Open-Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. With the TPS TEC, the TPS voltage is enhanced at 70% throttle, assuring maximum TPS voltage and maximum percentage of PE. This module also corrects for low sensor voltage and "dead spots" in the throttle range. LED indicators verify correct operation.
NOTE: This unit is not designed for "drive by Wire" equipped engines.
CASPERS NEW $89.95
I'M SELLING MINE $75 SHIPPED!!!!
262-483-8969
specialized
06-18-2022 09:26 AM
Azrael91966669
25
06-20-2017 04:04 AM
Brcharrelson
08-26-2015 07:47 PM
NBrehm
08-25-2015 11:49 PM
fonzie85
08-13-2015 11:50 AM
Quick Reply: CASPERS TPS ENHANCER #102015 TPI CARS
