FS: Fully ported heads, cast iron 64cc chambers
Selling a set of fully ported cast iron heads not just a gasket match here, full runner and bowl work, 64cc chambers, aftermarket valves with under cut stems for more flow, 1.94" intake and 1.50" exhaust. Heads are cleaned and assembled.
Heads flow just about 240cfm on the intake side at 0.550" lift.
These heads were off of a friends 79 camaro, he upgraded and i was going to use them on a project but have gone a different direction.
His camaro was running a consistant 11.80's at 116mph on motor, stock bottomend with flat top 4 valve relief hyperutectic pistons, single plane intake, 750 carb, compcams flat tappet single pattern 248 dur @ 0.050" cam (off the self cam), 1 5/8" long tube headers, 350 trans with a jegs converter, 3.73 gears and southside lift bars in a stock weight car, just listing his setup to see what these heads can do with a very average setup.
Casting numbers on the heads are 186 & 462, one head has accessory holes and the other doesn't, heads are the same in everyway from ports to chambers, setup this way so that you have two sets of usable heads rather then one set.
$400 for local pick up or add shipping.
Located in NJ 08721
Tony
email me any questions at KrazedZ@yahoo.com
Located in NJ 08721
Tony
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
