vortech supercharger and much more!
Old Jan 5, 2008 | 06:02 PM
scaryjerry's Avatar
Transmission: t-5
Im located in delavan wisconsin. im parting out my engine and tranny set up and building something new. All parts do NOT include shipping and shipping charges with only be what they really are. WILL TRADE ALSO.
1.) Vortech supercharger kit that is 3 years old. I bought this new. This is a gear charger ( has a nice wine to it). comes with a used gaterback belt, braded oil feed line with fittings, k&n air filter, bosh mass air flow sensor, all the brackets, all the bolts, but one that broke. (i still have it and will include it so you can get a new one) Msd btm box( only used for a week and then i took it off and just used a boost fuel pressure reg. and did tunning in the ecm.) fmu, A 1 to 1 boost fuel pressure reg, a 2 peace rearmain oil pan with the return oil line in it, comes with 3 pulleys. (stock one, 3.33 and 2.73), stock crank pulley and spacer, brand new wallbro 255 intake pump still in plastic, bosh blow off valve welded into the intake pipe. all brackets were hand polished and so was the blower. You get everything in the pic and the only reason im getting away from it is becuase im going to carb with nos. ASKING 1700
http://i120.photobucket.com/albums/o...l/DSCF3566.jpg
FUEL PUMP
http://i120.photobucket.com/albums/o...l/DSCF3565.jpg
BLOW OFF VALVE
http://i120.photobucket.com/albums/o...l/DSCF3564.jpg
OIL PAN WITH RETURN LINE.
http://i120.photobucket.com/albums/o...l/DSCF3563.jpg
BLOWER
http://i120.photobucket.com/albums/o...l/DSCF3562.jpg
BLOWER
http://i120.photobucket.com/albums/o...l/DSCF3561.jpg
http://i120.photobucket.com/albums/o...l/DSCF3560.jpg
MASS AIR FLOW SENSOR
http://i120.photobucket.com/albums/o...l/DSCF3557.jpg
PULLEYS
http://i120.photobucket.com/albums/o...l/DSCF3556.jpg
BRACKET
http://i120.photobucket.com/albums/o...l/DSCF3555.jpg
VORTECH!
http://i120.photobucket.com/albums/o...l/DSCF3554.jpg
EVERYTHING YOU WILL GET!
http://i120.photobucket.com/albums/o...l/DSCF3553.jpg
FUEL PRESSURE REG.
http://i120.photobucket.com/albums/o...l/DSCF3552.jpg
PART NUMBERS ON BLOWER
http://i120.photobucket.com/albums/o...l/DSCF3551.jpg
MSD BTM
http://i120.photobucket.com/albums/o...l/DSCF3550.jpg
MSD BTM
2.) 749 ECM. has no chip. ( i know i have a stock chip if i can find it) ASKING $75
http://i120.photobucket.com/albums/o...l/DSCF3546.jpg
http://i120.photobucket.com/albums/o...l/DSCF3547.jpg
3.) SPEED DENSITY CONVERSION!
i made this jumper that plugs into your stock 165 ecm and reroutes the wires to a 730ecm. their is 4 seprate wires. one to knock sensor and 3 to the map. This comes with a 2bar map and a knock sensor. the chip in the 730 ecm is set up for 30lbs injectors and everthing else was stock. ASKING 350
http://i120.photobucket.com/albums/o...l/DSCF3542.jpg
http://i120.photobucket.com/albums/o...l/DSCF3540.jpg
http://i120.photobucket.com/albums/o...l/DSCF3539.jpg
http://i120.photobucket.com/albums/o...l/DSCF3538.jpg
4.) MSD ELECTRIC FUEL PRESSURE GAGE. 100PSI ASKING 75
http://i120.photobucket.com/albums/o...l/DSCF3544.jpg
http://i120.photobucket.com/albums/o...l/DSCF3543.jpg
http://i120.photobucket.com/albums/o...l/DSCF3545.jpg
5.) MSD BLASTER COIL FOR ANY TPI OR THROTTLE BODY CAR ASKING 20
http://i120.photobucket.com/albums/o...l/DSCF3155.jpg
http://i120.photobucket.com/albums/o...l/DSCF3154.jpg
6.) A/C DELETE PULLEY ASKING 30
http://i120.photobucket.com/albums/o...l/DSCF3549.jpg
7.) STOCK TPI DISTRIBUTOR ASKING 30
http://i120.photobucket.com/albums/o...l/DSCF3548.jpg
8.) SET OF 4 GTA RIMS. ( REFINISHED AND HAND POLISHED) ASKING 400
http://i120.photobucket.com/albums/o...l/DSCF3141.jpg
9.) CHROME CHEVEY SHORT STYLE VALVE COVERS. ASKING 20
http://i120.photobucket.com/albums/o...l/DSCF3161.jpg
http://i120.photobucket.com/albums/o...l/DSCF3160.jpg
10.) CRAN CAMS POLY LOCKS 3/8 NEW IN BOX NEVER USED! ASKING 20
http://i120.photobucket.com/albums/o...l/DSCF3157.jpg
http://i120.photobucket.com/albums/o...l/DSCF3158.jpg
11.) STOCK V-8 BELL HOUSING WITH SHIFTING FORK. ASKING 50
http://i120.photobucket.com/albums/o...l/DSCF3147.jpg
12.) T-5 SET UP. WORLD CLASS V-8 5 SPEED WITH B&M RIPPER SHORT THROW SHIFTER AND A AUTOZONE CLUTCH WITH LESS THAN 1K ON IT. (YOU CAN STILL READ FLYWHEEL SIDE ON IT) ASKING 500
ASKING 700 AND IT COMES WITH ALL THE HDY, PEDALS, AND SHIFT PLATE OUT OFF A 88 FIREBIRD WITH POWER WINDOWS. NICE SHAPE!
http://i120.photobucket.com/albums/o...l/DSCF3186.jpg
http://i120.photobucket.com/albums/o...l/DSCF3185.jpg
http://i120.photobucket.com/albums/o...l/DSCF3182.jpg
http://i120.photobucket.com/albums/o...l/DSCF3173.jpg
http://i120.photobucket.com/albums/o...l/DSCF3174.jpg
13.) 153 TOOTH FLYWHEEL FOR A 2 PEACE REARMAIN ASKING 40
http://i120.photobucket.com/albums/o...l/DSCF3183.jpg
14.) BRODIX 11X HEADS WITH MATCHING CAM, 1.6 ROLLER ROCKERS 7/16 STUDS, CROWER RETRO FIT ROLLER LIFTERS, HARDEN PUSHRODS, FRESHENED UP IN MARCH. LESS THAN 1K ON EVERHTING. ASKING 1700
http://i120.photobucket.com/albums/o...l/DSCF3234.jpg
http://i120.photobucket.com/albums/o...l/DSCF3232.jpg
http://i120.photobucket.com/albums/o...l/DSCF3227.jpg
http://i120.photobucket.com/albums/o...l/DSCF3224.jpg
http://i120.photobucket.com/albums/o...l/DSCF3220.jpg
http://i120.photobucket.com/albums/o...l/DSCF3215.jpg
http://i120.photobucket.com/albums/o...l/DSCF3212.jpg
15.) 383 stroker kit from eagle. cast steal crank 350 mains, with 3.75 stroke, 5.7 i beam rods. keith black hypereutectic pistons. 2 pistons are cracked in the same place. (ater this i think hypereutectic are junk and i would only do forged!, your choice to get 2 new ones or a new set. pistons are floating, and they have spiral locks.
asking 350
I HAVE ALOT MORE PICS, JUST ASK. OTHERWISE CALL....... 262 745 2432
Old Jan 5, 2008 | 08:21 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
Re: vortech supercharger and much more!
Very intersted in the supercharger kit. Would love some more pics to Bobbyss23@aol.com. Thanks!
Old Jan 5, 2008 | 10:45 PM
jbpnumber03's Avatar
I would LOVE pics of the stroker kit to JBPNumber3@comcast.net
thanks
Old Jan 7, 2008 | 12:27 PM
scaryjerry's Avatar
Transmission: t-5
bump.
Old Jan 8, 2008 | 09:55 PM
scaryjerry's Avatar
Transmission: t-5
I DO ACCEPT PAYPAL!
Old Jan 10, 2008 | 12:30 PM
WLKD OFF's Avatar
Car: 92 Z28 Camaro
Axle/Gears: 373, strange axels
I am very interested in the supercharger set up you have. What kind of trades would you be interested in? Was also wondering about the power difference it made in the car did you ever run it in the 1/4 mile or anything. If you could get back to me asap i would greatly appreciate it. My email is bertsnos150@yahoo.com. Thanks Bert
Old Jan 10, 2008 | 08:04 PM
scaryjerry's Avatar
Transmission: t-5
SUPERCHARGER KIT JUST SOLD TO SIMZ28!!! THANKS FOR COMING AND GETTING IT!
Old Jan 10, 2008 | 08:21 PM
simz28's Avatar
Engine: LS1, 5.3
Glad to hear everything went well. My brother is pretty excited to get this and said that you were a good guy to deal with. Thanks
Old Jan 11, 2008 | 11:20 PM
scaryjerry's Avatar
Transmission: t-5
ttt
Old Jan 13, 2008 | 10:56 PM
scaryjerry's Avatar
Transmission: t-5
anyone
Old Feb 17, 2008 | 10:00 PM
Ericheee's Avatar
Want a title? Post!
Car: 1987 chevy camaro iroc-Z28
Engine: 5.7 Litre TPI 5 speed
Transmission: 5 speed trans.
Axle/Gears: it currently has 3:73 gears
im interested in the trans
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Sep 30, 2015 07:48 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
