PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM
Old Jan 24, 2008 | 01:12 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
I am sellin a ported stock tpi intake freshly glass beaded...looks brand new. I also Have siamesed slp runners tha have been sanded down and pollished. The plenum has been ported and pollished also. All of these parts have been glass beaded inside. I had planned on puttin this stuff on a 383 I am building but I am going to go with a mini ram instead b/c of the size of the cam. I will sell the whole setup minus a throttle body for $750. This includes the: ported and glass beaded base, slp runners(pollished), plenum(pollished), Distributor(stock w/ accel hei module and coil), fuel rail, slp air foil,and gasket set.
Old Jan 24, 2008 | 03:25 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM
what year unit is it?
Old Jan 24, 2008 | 04:02 PM
peepsrs's Avatar
Car: 91 Rs
It is a 86 setup with the extra cold start 9th injector. I just found out I need to get the 30lb injectors so the injectors are for sale as well for an extra $200. they are accell 24lb injectors and they are less than a year old w/ less than 10,000 miles
Old Jan 25, 2008 | 11:03 AM
Matterform's Avatar
Hi:
How much for the runners?
interested
B
Old Jan 25, 2008 | 11:12 AM
peepsrs's Avatar
Car: 91 Rs
I dont want to piece it out but I will If I have to. Runners and plenum $500.
Old Jan 25, 2008 | 11:16 AM
peepsrs's Avatar
Car: 91 Rs
here are some pics
Attached Thumbnails PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM-tpisetup.jpg   PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM-tpibase.jpg   PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM-tpibasebottom.jpg
Old Jan 25, 2008 | 11:23 AM
peepsrs's Avatar
Car: 91 Rs
as you see I didng pollish the back of the runners b/c they are not visible. you can also see the port work on the inside
Attached Thumbnails PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM-runnerback.jpg
Old Jan 25, 2008 | 11:26 AM
peepsrs's Avatar
Car: 91 Rs
the ports on the base
Attached Thumbnails PORTED TPI INTAKE W/ SLP POLLISHED RUNNERS AND PLENUM-tpibaseport.jpg
Old Jan 25, 2008 | 10:20 PM
peepsrs's Avatar
Car: 91 Rs
I have a set of accell 24lb injectors with 5k on them I will include in the $750 package for everything. I will sell them seperately for $175
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
meeklay812
Oct 1, 2015 03:46 PM
