3.27 gears for 9 bolt rearnd
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
gears in great condition. only 75,000 milers on them. $75 shipped in lower 48
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
Re: 3.27 gears for 9 bolt rearnd
will these fit my 86 trans am... currently have a 9 bolt 2.77... it's pretty sloppy with an annoying clang when put into drive, plus the jump in gears would be nice.... would you ship to tucson? would you know if i need any other parts for the swap? Thank you!
doncar_336@comcast.net is my acct. #.
thanks, don
yes they'll bolt right in. i have the ring and pinion. thats all you need i believe. $75 shipped. i take paypal if you're interested.
thanks, don
thanks, don
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
interested but i would have to see pictures before anything else
Car: 89 Iroc Convertible
No they wont fit.The 2.77 gear 9 bolt is a 2 series carrier and will only fit up to 3.08.To fit a 3.27 gear you would need a 3 series carrier.Just an FYI
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
I have a 9 bolt and just went from a 3.08 to a 3.45 and had to change the differential. I'm sure 3.08 ,2.77 are 2 series differentials. I have an extra 3 series posi differential if someone is interested.
Yes Im positive it wont fit.I am talking about the 9 bolt rearend which have 2 different carriers.The 2 series is for 2.77 and 3.08 gears and the 3 series is for 3.27,3.45,3.70...etc.
Car: 89 RS
Engine: 383 in building process
I second that. When I changed gears on my 9 bolt I had the 2.77 setup. Had to get the "3 series" carrier to run the 3.70 gears afterward. Member
Car: 1986 Trans Am
great comments, thanks....
hey, catc... how much for your 3 series posi 9 bolt borg warner differential?
so... the 3.27 ring and pinion, the 3 series carrier... anything else, masters yodas?
Car: 1985 Trans Am
I'm thinking around 80.00 plus shipping. I have no idea what it looks like inside. Also have a 3.27 gearset.
Car: 1985 Trans Am
Yes Still have a Limited slip differential and a set of 3.27 gears for sale , if your interested how about a pm or e mail? c.cat100@verizon.net
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
