89 L98 350 longblock and 700R4 in Atlanta,Ga.
Old Mar 19, 2008 | 08:00 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Removed from a 89 GTA with 111K and never rebuilt. The engine got a rod knock and was ran for maybe 5 minutes at the most after the knock started. It ran great before the knock started and still ran great with the knock. It did not happen from racing. The heads are removed and everything is good and the cylinder walls are good. I found a small piece of a crank bearing in the oil pan. No damage to anything else. This would be a easy rebuild or just polish the crank, resize the connecting rod with the bad bearing and new crank bearings for pretty cheap. No intake. This is the block, rotating assembly, heads, harmonic balancer and oil pan. $300 for the longblock. The 700R4 shifted great with no problems. TC is included. $250 for the 700R4. Local pickup, No shipping.
Old Mar 21, 2008 | 08:27 AM
Dokken10's Avatar
Car: 91 Formula
Re: 89 L98 350 longblock and 700R4 in Atlanta,Ga.
TTT
Old Mar 30, 2008 | 07:15 AM
Dokken10's Avatar
Car: 91 Formula
700R4 is sold. $300 OBO for the L98.
Vintageracer
Jan 10, 2020 05:33 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
Eric-86sc
Aug 24, 2015 09:01 PM
djmarch
Aug 11, 2015 10:22 AM
