Mallory 4309 fuel pressure regulator
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Used it for less than 500 miles, works fine.
$50
-Brent
$50
-Brent
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Re: Mallory 4309 fuel pressure regulator
This is one thing that I'm completely clueless about but wanting to own. Are these universal or made for a certain setup or what?
Car: 1986 Iroc
Engine: Afr 408
They are universal. It has 4 ports for whatever input and output you want to route. I used 2 inline, then just capped the other two. On the bottom is the return. All the ports and return are 3/8" NPT. On the top is where you adjust the pressure. They are pretty much meant for carb applications, I think they regulate fuel in 5-12 psi range.
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Damn, this pisses me off! Every time I buy something on ebay I find it two days later on here for cheaper.
I have been looking on here for the last 2 months and just went ebay since my motor is just about together.
Sorry for butting in and good luck it shouldn't take long to sell.
Hey Cam-aro, this is THE regulator everyone uses when converting a TPI car to carb. It allows you to dial down the high pressure from the TPI fuel pump to where you can run a carb without having to change anything with the fuel pump setup. Most regulators just deadhead, and don't have a return port. You have to have a return, or it puts too much strain on the in-tank pump.
Car: '91 Z28
