TPS VOLTAGE BOOSTER/ TPI CAMARO/TRANS AM
Old Jun 29, 2008 | 10:20 PM
smallblockking's Avatar
TPS voltage at Wide-Open-Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. With the TPS TEC, the TPS voltage is enhanced at 70% throttle, assuring maximum TPS voltage and maximum percentage of PE. This module also corrects for low sensor voltage and "dead spots" in the throttle range. LED indicators verify correct operation.
This is a brand new piece new from caspers $92.95 brand new in the box.
Looking to get $75.00 shipped
****!!! NO PAYPAL!!! ****
Old Oct 30, 2008 | 07:29 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: TPS VOLTAGE BOOSTER/ TPI CAMARO/TRANS AM
Very interesting. Never saw anything like this before!
Old Oct 30, 2008 | 09:22 PM
[QUOTE=smallblockking;3806548]TPS voltage at Wide-Open-Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. With the TPS TEC, the TPS voltage is enhanced at 70% throttle, assuring maximum TPS voltage and maximum percentage of PE. This module also corrects for low sensor voltage and "dead spots" in the throttle range. LED indicators verify correct operation.
Looking to get $70 shipped, add3% paypal
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
