COMP EXTREME ENERGY 294 HYDRAULIC ROLLER CAM FOR SALE
Old Jul 26, 2008 | 03:13 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
COMP CAMS EXTREME ENERGY 294 HYDRAULIC ROLLER CAM.2000 MILES ON IT
changing cams due to different combo for next year........200.00 shipped..add 3% for paypal<Badass355ciz28@aol.com>
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Part Number: CCA-08-443-8
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,800-6,100
Intake Duration at 050 inch Lift: 242
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 242 int./248 exh.
Advertised Intake Duration: 294
Advertised Exhaust Duration: 300
Advertised Duration: 294 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.562 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.562 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: CS XR294HR-10
Old Jul 27, 2008 | 03:51 PM
Re: COMP EXTREME ENERGY 294 HYDRAULIC ROLLER CAM FOR SALE
to the top
Old Jul 29, 2008 | 10:44 PM
make me a reasonable offer.needs to go
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
