9 bolt things
Old Sep 9, 2008 | 02:20 PM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
9 bolt things
i have a 3 series posi carrier. i also have the stock axles from this rear end and the disc brake backing plates, ill have some pics shortly. make reasonable offers, i would also consider any/all of these parts for trade and some cash for a HSR or mini ram.
Old Sep 9, 2008 | 02:46 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt things
What gear Ratio is the Carrier and How much do you want for it?
Old Sep 9, 2008 | 02:50 PM
Car: 86 Trans Am
Engine: 383
Re: 9 bolt things
its a 3.70, but the pinion has a chip in it so its going to be trashed
Old Sep 9, 2008 | 03:21 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: 9 bolt things
How about the backing plates? PBR brakes or the old iron caliper type?
Old Sep 9, 2008 | 05:05 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt things
When it was chipped, did it make anynoises? Is the Carrier itself fine?
Old Sep 9, 2008 | 05:26 PM
Car: 86 Trans Am
Engine: 383
Re: 9 bolt things
wasnt making any noises that we heard, just your typical loud third gen exhaust. its a rear i took off my buddys car as he switched to a 4th gen rear, although this is not the original rear for his car so not sure what its originally off of. it was missing the ratio tag and i always wanted to tear into one of these 9 bolts and sure enough i found the chip.
correct me if im wrong but i believe these to be the pbr.
Last edited by pearlphoenix; Sep 9, 2008 at 05:30 PM. Reason: Automerged Doublepost
Old Sep 9, 2008 | 06:27 PM
Mongoose's Avatar
Car: 90 Formula
Re: 9 bolt things
Yep, how much you looking to get for them?
Old Sep 20, 2008 | 07:35 PM
Mongoose's Avatar
Car: 90 Formula
Re: 9 bolt things
You still looking to sell the backing plates?
Old Sep 21, 2008 | 12:32 PM
Car: 86 Trans Am
Engine: 383
Re: 9 bolt things
backing plates are sold
Old Sep 21, 2008 | 12:52 PM
Mongoose's Avatar
Car: 90 Formula
Re: 9 bolt things
Thanks.
Old Sep 21, 2008 | 10:33 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt things
How much are you looking to get for the carrier?
midge54
Dec 27, 2019 04:14 PM
LittleFranks
Aug 20, 2015 03:55 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
