3rd. gen 10 bolt and 700r4
i have for sale is the rear from my 86' z28. its got 3.73 gears. and eaton gov. lock diff. 28 spline Superior Axle's new backing plates. drums break hard wear new drum cylinders. new S.S. break lines on the axels. and come with a new s.s. break line from the proporsin valve to the rear with a s.s. earls line. it has around 1500 miles on it. . and a fully built 700r4
gearing is matched for 3.73
ALL NEW BUSINGS
5 pinion front and rear planterys
trans go 700 shift kit
beast sun shell
13 vane pump
.450 boost valve
ALTO WIDE KEVLAR BAND / REVERSE INPUT DRUM
high performance intermediate billet servo
high performance overdrive billet servo
29 element Borg Warner forward input sprag
low / reverse spring and roller
Alto RedEagle PowerPack for the 700R4
Transgo performance valve body plate
..there is some other thing i just cant remember. everything in the tranks was changed
pick up only in NJ. im in bayonne, nj. $1700. and if you take it i'll throw in the 3' flow master American thunder exhaust
ALL NEW BUSINGS
beast sun shell
13 vane pump
.450 boost valve
Car: 1987 Monte Carlo SS Aerocoupe
Engine: 305 H.O.
Transmission: 700-R4
Axle/Gears: 3:73 Posi
Re: 3rd. gen 10 bolt and 700r4
how much for just trans if available separate? does it have a stall convertor or anything to go with it? Lemme know... (217)493-4751 or email at zkeeter@stu.parkland.edu
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
how much for just the rear? email at rbain60@hotmail.com
I am in Nutley, NJ...easy sale.
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
dhonda200
Aug 11, 2015 11:50 PM
