383 SBC and 700r4
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
383 SBC and 700r4
383 Stroker
• 4.040" bore 10.1:1 compression
• Eagle Cast Steel 3.750" Stroker Crank
• Reconditioned 5.7" Rods
• SRP Flat Top Forged Pistons 10.1:1 Compression
• JE Pro Seal Piston Rings
• Trickflow Cam Hydraulic Flat Tappet, Advertised Duration 308/316, Lift .495/.510, 112 Lobe PowerBand 3500 - 6700rpm
• Trickflow Billet Steel Double Roller Timing Chain
• Trickflow Hydraulic Flat Tappet Lifters
• Trickflow Heads, CNC 23 Degree, Aluminum, 72cc Chamber, 195cc Intake Runner
• Trickflow Chromemoly Pushrods 5/16" Diameter, 7.850" Length
• Trickflow 1.5 Aluminum Roller Rockers 3/8"
• Edelbrock Victor Jr Intake Single Plane 3500-8000rpm
• Moroso 7 Quart Oil Pan
• Summit High Volume Oil Pump
Went 11.2 in a 3300 lbs camaro and 9.70 with a 250 shot. this was through a 700r4 with a jegs converter. i also have the 700r4 also.
Motor - $4500 W/ Tranny $5500
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: 383 SBC and 700r4
How much for longblock assembly. No intake
Thanks,
Thanks,
Car: 1987 IROC
for the long block it will be $3800
i have been 9.70 with the 700r4
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
