Complete Heads
Old Nov 1, 2008 | 04:41 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Complete Heads
I have a set of Chevy Bowtie Steel heads that have angle plugs and are good for 600 lift. These are ready to bolt on. They have 2.02-1.60 valves.
500.00 Firm
Also I have a BRAND NEW cam and lifter set. It is a solid lift mechanical Flat Tappet Cam.
Specs are:
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 248
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 248 int./248 exh.
Advertised Intake Duration: 294
Advertised Exhaust Duration: 294
Advertised Duration: 294 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh. lift
Lobe Separation (degrees): 110
200.oo for the cam and lifters
Last but not least I have a Gear Drive set -40.00
Old Nov 2, 2008 | 01:12 AM
afida15's Avatar
Re: Complete Heads
Are you looking for any trades?
Old Nov 2, 2008 | 05:52 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: Complete Heads
maybe, what do you have to trade?
Old Nov 2, 2008 | 10:29 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: Complete Heads
Not really interested in Heads because I want to go with Aluminums, but $200 Shipped for the Cam/Lifter Set?
Old Nov 3, 2008 | 05:28 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: Complete Heads
yea I could do that
Old Nov 8, 2008 | 08:19 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: Complete Heads
Cam and Lifters sold pending payment
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
