i will trade my tpi for carb and auto for manuel
Guest
Posts: n/a
i have a 87 iroc-z 5.7 with a rebuilt tranny has shift kit as well. i will trade tpi for carb setup and i will trade my auto for a manuel setup. tranny has been rebuilt has less than 1500 miles on it and has nice shift kit with corvette servo
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
Re: i will trade my tpi for carb and auto for manuel
you should post this in the "Classifieds" section on the main page. You might get a couple hits.
Car: 1989 Camaro
Engine: 383
Too bad your not closer, I need that TPI on my boat and that auto in my Camaro.
Guest
Posts: n/a
Where in IN ? I'm in OH just across from Ft. Wayne, IN. Can solve both of your problems. I have a Edelbrock Torqer II and a Performer RPM along with a nearly new Edelbrock carb. Also have a Z28 out here that is destined for the drag strip, manual car with everything you need, I'm gonna make it a auto car. I have never tested the tranny because the car has never ran since I aquired it, trailered it here. Because I won't stand behind the tranny you can keep yours. I'll give you tranny, clutch pedal assembly, shifter, center consol if you need it, carb, intake of your choice, distributor for your TPI including ECM and auto pedal assembly. Oh yea, and part of your Sat. to help pull the parts
I don't know if you have found someone to trade you or not, but if by chance you are still looking I have a Edelbrock Performer RPM along with a nearly new Edelbrock carb on my 86 IROC that I would trade you for that tpi setup. I'm in Muncie, IN with a heated 2 car garage that we could do the swap at (I'll help you all I can if you could help me as well) if interested send me a pm or something.
thanks
thanks
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
