305tbi motor, trans etc, etc
Old 12-01-2008, 08:20 PM
bygblok's Avatar
pulled from my VERY nice 92 RS. 305tbi motor, 700r4 trans, radiator, complete AC system(hoses, condenser, evap, case) engine AND trans K-members, mounts, a-arms, sway bars, springs, etc, etc. I went LS1 with all tubular stuff and coil-overs and this stuff is truly in my way. I also have the ECM harness to the motor and the ECM(harness has been opened and essential body harness wires removed, not completely hacked) cruise module, driveshaft.....you name it drivetrain-wise and I probably have it here. Even have the stock y-pipe, cat and dynomax cat-back. I'll help with delivery within 200 miles of Pensacola Florida. $900 for everything I have. Help me...I need the ROOM!!
Old 12-05-2008, 05:58 AM
bygblok's Avatar
Re: 305tbi motor, trans etc, etc
trans is sold along with some other stuff I had for an S10. Still have a GREAT running 305tbi motor, electronics, cruise module, harnesses, radiator, AC parts........ ALL the steering parts and k-members!! I need this stuff outta my way before I just scrap it all!!
Old 06-16-2009, 02:34 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
still have the stuff above
Old 06-16-2009, 04:42 AM
bygblok's Avatar
most everything is gone now other than some steering parts, the front brakes(everything from the booster to the calipers) I also have all the air bag sensors, most every connector for under the dash parts I didn't use, two or three miles of wiring!! exhaust, etc, etc. Be a little more specific as to what you might need and I'll see what I can do. Thanks for asking, Bill
Old 06-16-2009, 09:15 AM
FueledSoul's Avatar
I'm looking for following parts
82-92 Stock Spindles with no damage.
82-92 Lower Control Arms with out heavy rust or no rust
82-92 Stock springs,
Old 06-22-2009, 01:35 PM
bygblok's Avatar
sorry about not getting back with you....... I've got a perfect set of lower arms and RS v8 springs as well. I had to use and cut the stock spindles for my aerospace brakes though. Not sure about shipping because the stuff is pretty big and heavy as well. Also have all the stock steering parts(box, centerlink, tie rods etc) sway bar, complete front brake system including the MC and booster, front engine brackets for a serpentine setup(tbi) Get with me if you're still interested. Thanks, Bill
Old 04-08-2010, 12:39 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
i need centerlink and idler arm etc. thanks munks@optonline.net
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
stalkier
08-13-2015 12:59 PM
armybyrd
08-10-2015 09:23 PM
Leggman1
08-06-2015 04:15 AM
Quick Reply: 305tbi motor, trans etc, etc
