FS: (names like - MSD, Edelbrock, Moroso, Earls, K&N, GM, LT4 (IROC & TRANS AM PARTS)
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
A lot of this stuffs brand new in less otherwise noted:
If it doesn't sell before 01/04/2009 i will be listing whats left on ebay. I take paypal, money orders or cash in person. Im selling these parts on a first come first serve basis at my asking prices. every things being shipped from Minnesota.
I will only ship to the lower 48 ( stuff sold will be marked as sold)
2 - Earl's Performance Auto-Fit Hose Ends
Fitting, Hose End, Auto-Fit, Straight, -4 AN Hose to Female -4 AN, Aluminum, Red/ Blue,
Fitting, Hose End, Auto-Fit, 45 Degree, -4 AN Hose to Female -4 AN, Aluminum, Red/ Blue,
4 -Earl's Performance Brake Adapters
Fittings, Brake Adapter, -4 AN to 1/ 2-20 in. Inverted Flare, Aluminum, Blue,
All brand new
$70 shipped for all
1 - used MSD Blaster GM Coil
Ignition Coil, Blaster Performance Replacement, E-Core, Square, Epoxy, Red, 48,000 V, GM
$40 shipped
NEW chrome timing cover, gaskets, bolts and a timing tab
$14 shipped SOLD
New Moroso Blue Max Spiral Core Spark Plug Wire Set
Spark Plug Wires, Blue Max, Spiral Core, 8mm, Blue, 90 Degree Boots, Universal, V8, Set
Assembled: No
Diameter (mm): 8.00mm
RFI Suppression: Yes
Wire Color: Blue
Distributor Terminal Ends: Male/HEI and Female/Socket
Distributor Boot Color: Black
Distributor Boot Material: Silicone
Spark Plug Boot Ends: Eight 90 degree
Spark Plug Boot Color: Black
Spark Plug Boot Material: Silicone
Coil Wire Included: Yes
Conductor Style: Stainless steel alloy
Quantity: Sold as a set.
All brand new
$70 shipped for all
$40 shipped
$14 shipped SOLD
Assembled: No
Wire Color: Blue
Re: FS: (names like - MSD, Edelbrock, Moroso, Earls, K&N, GM, LT4 (IROC & TRANS AM PA
$62 shipped
Used for under 2 miles - Moroso Red Max Spiral Core Spark Plug Wire with heat sleeves
Assembled: Yes
Wire Color: Red
$50 shipped
Assembled: Yes
Wire Color: Red
$50 shipped
New GM LT4 valve springs (came take up to .525" of lift) LT4 locks and retainers
$65 shipped
New 1" carb spacer with vacumm fitting gaskets and all hardware
$25 shipped
New 360 degree swivel water neck chromed aluminum
$30 shipped
New Edelbrock Throttle Cable Brackets
Throttle Cable Bracket, Steel, Cadmium Plated, Chevy, Small Block
$25 shipped
New Edelbrock Throttle Return Kits
Throttle Return Spring, Natural, Dual Spring, Bracket, Universal, Kit
$12 shipped
New K&N Recharger Filter Care Service Kits
Air Filter Cleaner/ Oil, Recharger
$12 shipped
New 18" x 3" round slash cut polished stainless steel tips
might need to be lightly polished due to siting in boxes
$65 shipped
New throttle cable fits VIN with the letter G engine code
$10 shipped
New single groove pulley with lock and nut for sbc
$10 shipped
New intake boot
$10 shipped
slighy used MSD cap with new rotor
cap drop and broke will still work see pic above
$10 shipped
used K&N air filter and snorkel
$35 shipped
long round tips scratches, gouges, chips
Make offer any offer!
rocker emblems one is missing the tabs in the back see pic make offer
LT1 stuff
2- MAP's
1 -TPS
1- IAC
Open to offers on each or all
GTA horn button one tab on the back missing see pic
$15 shipped
Equalizer 2 buttons broke (bought from a auction along time ago never tried to see if it worked
Sold as is! $10 shipped
Trans am map pocket 1 rip see pics
$30 shipped
single fan make offer
air snorkel $15 shipped
used $12 shipped
used polyurethane end links
$7 shipped
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Ill Take the timing cover and associated hardware.
Pm me, Thanks.
Pm me, Thanks.
bump
$65 shipped
$65 shipped
$65 shipped
$65 shipped
just let me know thanks
i will take a look
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
What is the specs on the blue intake boot? is for TPI tb to 3in? Thanks
consider the lt4 springs, locks, and retainers sold if the deal i have with another guy on ls1tech to get the hot cam and rockers works out.
Jeremy
Jeremy
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
would you be willing to se the bottom tray for the single fan stup. mine broke this weekend when the motor was coming out. let me know. may be instested in the throttle bracket as well. let me know how much shipped to 49331.
sure i guess so. i will get back to you on that with shipping. you want the Edelbrock one thats gold zinc coated?
Engine: Vortec 357
yes please
Car: 1987 Trans Am
PM me i don't check this thread this often the timing cover is sold!
The intake boot was a spare i had for one of my lt1 cars
it conects to the MAF and a 3" tube
I will be out of town for a week anyone that has sent me a PM with in the last few days i will try to get back to some time by next week. i will post here when im back in town
Car: 1990 iroc-z twin turbo
Engine: l98 350
Transmission: t-56
do you still have the z-28 emblems how if so how about 20.00 plus shipping to 19014
rear
Engine: l98 350
Transmission: t-56
thats ok with the tabs missing how about 10 or 15 bc they are messed up
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
