91 305 tpi motor for sale, So.Cal $650
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
This motor was going in my 85 TA but sold the 85 to keep my 91 TA.
Motor info as follows.
305 tpi from 91 5 speed Z28 with 80K, complete from pan to tpi front aluminum pulley set up, exshuast manifolds. I have a new Z28 factoy oil pan w/baffles and 1 pc gasket. new balancer,new double roller timing chain, new oil pump and pick up(welded). ecm (165) with engine harness(has area that touched hot exhuast manifold) has 081 heads(+) lots of parts and I want to sell everything together. while in the process of converting to the 85, I also have a new flex plate for a 700r4, but do not have the manuel flywheel, crank shaft has bushing in it still for the 5 speed still. currently the oil pan is off from checking out the main and rod bearing(looks good) timing cover is off also to replace timing chain. so if you want to really see what you are getting now is the time, if it does not sell quickly I'll put everything back together and remove from engine stand. asking $650 for everything. can be seen in the Lancaster/Palmdale area,pick up only. PM and we can trade phone #'s, give me time to respond.
Thanks Craig
Thanks Craig
Last edited by 85gulstrandTA; Feb 8, 2009 at 12:57 AM. Reason: harness not as bad as I had stated
Car: 1991 z28 vert
Engine: 5.7l tpi
Transmission: eh auto
Re: 91 305 tpi motor for sale, So.Cal $650
would this engine fit in my 1991 z28 camaro it has a 350 5.7l engine and an auto tranny the engine is messed up though
It will fit fine, but you are far away from me.
PM sent and phone call made, I will have pictures today.
Still working on pictures showing the bottomend and inside the heads, wiring harness and complete motor set up w/***. I will have many more that I will post so I could email then if needed.
NEW PARTS, pioneer double roller timing chain, speed pro oil pump w/welded pick up, balancer, z28 oil pan,flex plate, valve cover gaskets, water pump gaskets, total about $180.00, Summit's reciept alone is over $100 w/o pan,pump,or flex plate.
305 tpi still for sale, very clean and can sent pictures if emailed.
I can not post pitures here.
The wiring harness is not as rough i thought has a 3 to 4 inch area that hit the exhaust manifolds. Other that that it is pretty clean.
Motor is all sealed back up and painted gloss black with ceramic aluminum on the valve covers and exhaust manifolds, i have tons of pictures.
Looks Awsome....Also have new rear main seal.
very nice set up for the price, super clean inside and out, very complete
nobody needs a 305 tpi ?
super clean and ready to drop in with hundreds of dollars in extra's
all finished up with paint and polish looks awsome pm me your email and i can send just about any photo you want
Car: 1992 z28
Transmission: 5 speed
lots of pictures sent along with the small 4'' area of the wiring harness that touched the exhuast manifold, like i said before the harness is not rough at all, i made a mistake in the first post.
thanks for the interest, craig
pm sent to those wanting the harness/computer only. basically want to keep the harness with the engine untill the engine sells. at that time if the buyer does not want the harness/computer and does not want to sell to off set his/her cost of the complete set up i have...then i'll retain it and offer it here to the poeple that have inquired in the order they inquire to be fair. same go's for the aluminum accessory bracket.
thanks craig
thanks craig
LOOK AT THIS ON C/L FOR $100 MORE
I have the starter for it also....great motor...
I wish I could post pictures here to show how clean it is.
still for sale
great motor
still have any interest?
305 tpi still for sale email c.milligan@verizon.net for pictures
thanks....craig
thanks....craig
Thanks to craig's list the motor is sold..sold...sold
Car: 1992 camaro z28
Engine: 305tpi
Transmission: 5speed
Sanjay
Aug 12, 2015 03:41 PM
