BRE hyd. roller cam for 383-406
Old Jan 3, 2009 | 03:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Need a new cam this year so i'm selling my custom grind from Bret Bauer racing cams.
This was built for my AFR 195 headed 383 with 11 to 1 compression, holley stealth ram, and 3600 stall. Also has nitrous capability
Specs:
230/245 duration at .050" advertised 286/306 at .006" tappet lift
.603/.613" of lift with 1.6 rockers. .565/.575" lift with 1.5 rockers
Lobe seperation 109lsa.
Cam card included
Here's it idling at around 900-950 rpm
http://www.youtube.com/watch?v=B_5gI...eature=channel
Cam made 392/371 whp/wtq on a very hot day and with the motor very hot and heat soaked on its 10th pull. Coolant was over 205 degrees! This will put down 400-410rwhp once cooled down.
http://www.youtube.com/watch?v=bnon8...e=channel_page
Car at 3450lb raceweight has ran 11.4's at 118-119 on motor in the heat, with mediocre 1.55-1.62 60 foots. 10.6 at 127-128 on a 150 shot with a 1.45 60 foot. It has 10.50's in it, bottle was running low on that pass.
Great cam for fairly aggressive 383-406 combos. I would be hesitant to run it on a 355 unless your looking for a very aggressive setup thats still somewhat streetable. This cam in a 383 sounds mean but drives around just fine with no problems. Still good on brake vacuum
Asking 175 + shipping obo
Can send email .bin file for this cam/motor for those using MAF setups
Old Jan 10, 2009 | 07:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: BRE hyd. roller cam for 383-406
bump for a nice cam
Old Jan 10, 2009 | 07:54 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
very nice vids man love the car good luck with sale
Old Jan 11, 2009 | 07:06 PM
cleetus's Avatar
Mechanical fuel pump lobe?
Old Jan 12, 2009 | 06:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I will have to double check, as i dont remember. I want to say it does, but i'm not sure. Its still in the motor right now which is sitting on the stand. I have to pull the balancer off first before i can get a look at it.
Old Jan 12, 2009 | 06:29 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
damn i am suprised you still have this cam,it should have been long gone by now!!!!
bump for a cam that WORKS!!!!!!!
Old Jan 15, 2009 | 06:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Does have a fuel pump lobe
Old Jan 28, 2009 | 09:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Anyone?
Old Feb 8, 2009 | 01:17 AM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
still have it....it's for a 1pc rear main block....correct?
Old Feb 8, 2009 | 11:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yep cam was designed for 87+ roller motors
Old Feb 21, 2009 | 07:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
SOLD!!! Motor and cam are gone
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
