Mechanical gauges, valve guide seals, electric carb fuel pump, vacuum canister
Old Jan 19, 2009 | 10:01 PM
91chevywt's Avatar
Some things from my LT1 swap for sale. All prices do not include shipping.
Electric fuel pump for carb'd engines. Was working well before I started my swap. The cheaper ones new are $80 plus, I would like to get $30 firm for this one.
Auto Gauge Water Temp and Oil pressure gauges. Water temp gauge includes sending unit, oil pressure gauge basically threads into an oil artery and the line fills with oil to measure pressure. They are both mechanical and were both working, I'm just using electrical sending units so I'm getting new gauges. Also, the end on the oil pressure gauge line cracked (the brass fitting), so it should probably be replaced if it is going to be used. I would like $10 each, plus shipping.
Some LT1 gaskets, brand new. The valve guide seals are Viton material, thers 16 of them, and they are new, never opened. They have that little sleeve to protect themself when you install. I would like $15 for them, they are usually 25-30 new. Then theres water pump gaskets, exhaust gaskets, and that O-ring. Name a price on those
Valve Stem Seals Sold
I also have a Comp Cams vacuum canister, which can go for $20, but somehow the picture didn't make it. I have the black one. It's good for cams that don't make a lot of vacuum so you have a better chance with your brakes.
I have an LT1 a/c compressor, which I was going to use but decided not to since going a/c at the moment is out of my budget.
Old Jan 20, 2009 | 03:19 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Re: Mechanical gauges, valve guide seals, electric carb fuel pump, vacuum canister
Interested in valveseals.
shipping to zip 16401
I deal only with pay-pal
LMK, thanks
Old Jan 20, 2009 | 03:22 PM
partsbin321's Avatar
Car: 1987 Iroc
Engine: 502
Axle/Gears: Ford 9" 3.73
Do you still have the vac. cannister? Where are you located?
Old Jan 20, 2009 | 05:01 PM
91chevywt's Avatar
pictures added
LMK, thanks
I have one person whos interested first, then your next
I have two people ahead of you,then your next
Old Jan 20, 2009 | 05:12 PM
87SSTPI's Avatar
Ok, either way can you let me know if these are in fact for 11/32-inch-diameter valve stems?
Forgot to ask before, and that will determine if I should hold interest in these ones or not. I am still interested if they are the correct ones.
LMK, Thanks.
Old Jan 20, 2009 | 09:33 PM
91chevywt's Avatar
LMK, Thanks.
Valve Stem Seals have been sold.
Old Jan 21, 2009 | 07:07 PM
87SSTPI's Avatar
Thanks for the update.
:BUMP:
Old Jan 22, 2009 | 12:56 PM
91chevywt's Avatar
A/C compressor sold
Gauges are sold
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
