BBS Turbo header, HSR, 305 stuff...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 TA vert
Engine: turboLSx
BBS Designs single turbo header. I had Edgardo modify the typical design because I had my alternator mounted down low on the passanger side so the wastegate actually comes off the back of the header upwards towards where the downpipe would be run. I'm fairly certain it wouldn't work with A/C, it looks like the wastegate flange is right where the edge of the A/C box would be. Never been used, just mounted up for mocking purposes.
$325 + shipping.
EDIT; HSR and all associated crap have been sold.
$325 + shipping.
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Re: BBS Turbo header, HSR, 305 stuff...
How much for the HSR setup? and what size injectors?
Car: '91 TA vert
Engine: turboLSx
I know it's been awhile and I thought I had the header sold way back when but never got the moola. Friends are great friends until they have to pay. ![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
So, I still have the header available. Motor, HSR, headers and all associated other stuff is gone.
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
So the header is meant to mount a turbo in an LSx swapped third gen? I'd really be interested in a pic if possible! Is the turbo on the pass side or driver side? Thanks.
Car: 91 TA vert
Engine: 355
could you send pics to xiwastedyouthix@gmail.com please? thanks...
Car: 1988 Camaro
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 373
Do you still have the steath ram? What comes with it? and how much?
I'm interested in the turbo header. Please send pics to dark_1@hotmail.com
Car: '91 TA vert
Engine: turboLSx
Picture of it mocked up with an MPT70.
![Name: 0610082214.jpg
Size: 111.6 KB](https://www.thirdgen.org/forums/attachments/engine-drivetrain-suspension-parts/420628d1501482127-bbs-turbo-header-hsr-0610082214.jpg)
![Name: IMG_1178.jpg
Size: 110.5 KB](https://www.thirdgen.org/forums/attachments/engine-drivetrain-suspension-parts/420629d1501482127-bbs-turbo-header-hsr-img_1178.jpg)
![Name: IMG_1179.jpg
Size: 67.8 KB](https://www.thirdgen.org/forums/attachments/engine-drivetrain-suspension-parts/420630d1501482127-bbs-turbo-header-hsr-img_1179.jpg)
![Name: IMG_1180.jpg
Size: 105.9 KB](https://www.thirdgen.org/forums/attachments/engine-drivetrain-suspension-parts/420631d1501482127-bbs-turbo-header-hsr-img_1180.jpg)
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
If you still have this in about 1 month, I'll probably get it from you...
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
How much if I come pick it up?
Car: 87 Trans am
I just moved up to salem oregon so yeah I'm local.
I will see what happens in the next month and if its still for sale you'll hear from me
Car: '91 TA vert
Engine: turboLSx
Salem is still quite a ways from the Puget Sound area. ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
If you haven't already, check out www.cascadecrew.org It's a local board. Lot's of friendlies.
Car: '91 TA vert
Engine: turboLSx
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Still want to buy it?
![waveman](https://www.thirdgen.org/forums/images/smilies/waveguy.gif)
Car: '91 TA vert
Engine: turboLSx
Unfortunately I think with the huge thirdgen A/C box, it would hit. The waste gate flange is right near the edge of the box. It'd be touch and go and I think there would be problems.
Car: '91 TA vert
Engine: turboLSx
Before going LS* I had started to piece together a much smaller vintage air unit since when I bought when I was 20 I yanked the a/c with a quickness. hehe
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
#43
On Probation
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
i purchased a BBS header that was completely F'd up..that someone sold as being perfect...
if you change your mind, ill make you a hell of a deal..
Complete NX kit, with the big solenoids,all lines,bottle,brackets,jets,shark nozzle,HUGE purge kit{will purge a cloud 30 plus ft high}, wot bracket and switch...you wouldnt need a single thing to spray
#45
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Have you had it in a car? Looks like I may need to make a turbo "bump" in the hood with that big thing on there.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
#46
Car: '91 TA vert
Engine: turboLSx
With a mpt70 it's not above the hoodline. I don't know about larger turbos however? I haven't had it in the car, just on an engine stand and it was considerably lower than my HSR.
#48
On Probation
275 shipped? bout what id be willing to spend...
#49
Car: '91 TA vert
Engine: turboLSx
I literally JUST dropped it from 375 to 325... Poop.
300+shipping?
300+shipping?
#50
On Probation
