9" 3rd gen!! NEW! 496" BBC FRESH! $$$$
IN ATHENS GEORGIA!
New Moser 9" 35 spline Moser axles, Strange nodular S case, 4.10 gears with spool, 13" Ford drum brakes, torque arm mount, daytona pinion support, billet yoke, 5/8" long drive studs, all brand new, over $2700 when i purchased, is assembled and was installed in car but car was never finished. $2000, will arrange for pick up, will drive upto 100 miles to deliver! Shipping, might be able to arrange a truck freight, at cost.
ALSO:
Fresh 2 bolt main(ARP studded) 496"
New eagle cast steel crank
New eagle H beam Rods
New SRP 18cc dome forged pistons
Reworked Merlin Rect. Port 310 CC (Surfaced and New valve job!)
Herbert Solid roller .685" 253/266 @.050
Comp super roller lifters
Harland Sharp 1.7 Roller Rockers
Scat SFI cert. Flex plate
3/8" Pushrods
New head studs
Clevite trimetal bearings
Cometic head gaskets
1 peice oil pan gasket
New Milidon oil pan, kick out, i think its the 7 3/4" deep, it's the shallowest they had for our 3rd gens. Melling m77 with blue spring installed. The block work consisted Of, cleaning,clearancing for stroker crank, Line honing, Decking, Boring and Honed with plates. 2 preasseblies, and cleaning before final assembly!
The valve seats were not stone cut, the previous to do the heads did so, I had them cut right! Basically a 10.5-1 motor, the blocked was decked, pistons on .005" down in the hole, Also have a Wiend Team G Intake 4500 flange.. IT was Professionially built at Ewing Auto Machine in Snellville GA, I have been to some bad machine shops but this is the best I found so far!
Basically will drive out to 100 miles to deliver, or can arrange for truck frieght at cost. I will Have pics sunday! $4500 firm..
Call Troy @
706-247-1626
ALSO:
3/8" Pushrods
New head studs
Call Troy @
706-247-1626
