355 fs 600 obo in york pa
Car: 89 iroc
Engine: beefed 355 for now
Transmission: 700r4 for now
i have an 89 355 with cam around .525 lift hyper pistons crane rockers high flow oil pump new oil pan and gasket, also has a wieand intake. needs crank turned and bearings. 600 obo
Car: 89 iroc
Re: 355 fs 600 obo in york pa
i also have a good running 700r4. just installed shift kit. includes b&m cable too. 225 for trans or trans and motor for 700
Car: 86 SC Camaro drag car
Engine: 406
Transmission: Th350
Axle/Gears: 8.5 10 bolt 4.10
Could you gimme some more info on the engine?? Brand and part# of pistons, type of rods(stock, Eagle, Scat etc) Brand and # of cam? Any more info you may have would be greatly appreciated also. Where in York are ya located?
Car: 89 iroc
all of the internals i have no idea. i believe crank and rods are stock. pistons i just know they are hyperutetic. the cam idk i was just told the lift. i act live in dover. number is 8258598. this motor moves even with bad bearings. u can take a look and hear it run
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
