Ported/Polished Dart Pro 1's with port-matched intake
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
215cc Dart Pro 1's with 58cc chambers (have been milled) that have been ported and polished and flow great. I'll post the numbers when I get home and find them. They also already have the steam holes drilled for a 400 small block if you need to use them for that application.
In addition to this is a port-matched (to a Felpro 1206, same as the heads)Edelbrock Performer RPM Air-Gap intake.
These would cost around $1700 new without any of the machine work. I'll take $1300 for both. If you have any questions let me know.
Car: 1985 Z28
Engine: 383
Re: Ported/Polished Dart Pro 1's with port-matched intake
The heads are fully assembled with valve springs good up to .525" lift for a hydraulic flat tappet cam. If you would like different springs let me know as I'm going to be ordering a set of AFR heads and can simply order different springs on them and swap them out.
Car: 1985 Z28
Engine: 383
Not sure...I'll try to remember to go out in the garage tomorrow and check...been kinda a hectic week. I can tell you that they've got angle plugs on them as well.
Car: 1985 Z28
Engine: 383
Found the flow numbers for the heads today and they are as follows:
Lift I E
.2 133 104
.3 192 147
.4 241 184
.5 275 201
.6 291 209
Crystal, if you're trying to figure out if these are the Platinums, I can go ahead and tell you they aren't.
Lift I E
.2 133 104
.3 192 147
.4 241 184
.5 275 201
.6 291 209
86CamaroDan
Sep 29, 2015 10:08 PM
toronto formula
Sep 10, 2015 07:31 AM
