Roller Cam and LIffters
Old Apr 5, 2009 | 09:40 AM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
Roller Cam
LSM custom (mechanical) roller cam for small block Chevy
Crane mechanical roller Lifters #11544-16
Cam specs. 240/580int 245/580ext 110 lca
This cam is new (never ran)
The Lifters are used but like new approximately. 1000 street miles on them no racing I had a push rod brake and mark up the edge of the push rod seat on one lifter it is not bad and the lifter will function perfectly this is a full set of lifters (16)
new
Cam cost $425.00
Lifters over $500.00
I am asking $350. for both.
Old Apr 7, 2009 | 09:15 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: Roller Cam and LIffters
Will these work with iron heads?
thanks
kevin
Old Apr 7, 2009 | 08:30 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
I am not sure how to respond to your question without writing a book. But yes they will.
It dose not mater what your heads are made of for a cam and lifters to function.
Scot
Old Apr 7, 2009 | 09:36 PM
sstpres's Avatar
What is the Crane P/N? Adv. duration?
Old Apr 8, 2009 | 06:13 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
the cam is an LSM camshaft LSMENG.COM Advertised duration would be aprox 295int 302exh. depending on @.002 lift or .005 this cam has an agresive ramp profile with a resonable lift for a street/strip aplication. should make good power 3000-7000 rpm with just enugh vacume for power brakes
should have a lumpy idle, 3000-3500 stall converter.
Old Apr 20, 2009 | 04:01 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
any interest @ $300.00
Old Apr 20, 2009 | 05:07 PM
bear88ss's Avatar
Car: 88MCSS/92Firebird
Engine: 421/355
Transmission: TH-350/4L60
Axle/Gears: 4.11/2.73
Can you get a couple pics of the damaged lifter and will you separate?
Old Apr 21, 2009 | 04:11 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
It is hard to get a good pic. its so small the only damage is on the flat part of the lifter top The push rod seat is OK the red sircle is the dented airea it is non functioning. I do not wont to seporate at this time If you buy them and are not happy with the lifters after you see them. I will refund your money
Scot
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
