Parting Out 87 Iroc
Old Apr 30, 2009 | 06:23 AM
lee33lyn's Avatar
Car: 84 Z28
Transmission: 5speed
Axle/Gears: 3:23 posi disc brakes
Parting Out 87 Iroc
wrecked in front with frame damage complete car, what do ya need, t-top auto car blue with gray int.
Old Apr 30, 2009 | 07:15 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Parting Out 87 Iroc
Does she has rear disc brakes ? If so how are they working ? Would you sell the calipers alone ?
Old Apr 30, 2009 | 07:32 AM
lee33lyn's Avatar
Car: 84 Z28
drum rear brakes,but I do have another posi,rear with disc brakes I'm selling as a complete unit
Old May 2, 2009 | 09:25 PM
lee33lyn's Avatar
Car: 84 Z28
nobody needs anything?
Old May 4, 2009 | 06:30 PM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
What motor does it have?
Old May 5, 2009 | 05:27 AM
lee33lyn's Avatar
Car: 84 Z28
305 TPI runs good with automatic trans
Old May 5, 2009 | 07:54 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I am interested in the fuel pump relay port. Not the relay itself but the actual plug.
Old May 5, 2009 | 09:34 PM
mvp2ceo's Avatar
Car: 87 IROCZ
Transmission: 700R4 shift kit, corvette servo...
Axle/Gears: 26 spline 4.10 mini spool
i am interested in the dash pad if its got good corners i dont care about cracks..... if you have it how much and where are u? im in ohio
Old May 6, 2009 | 01:11 AM
ky_kneedragger's Avatar
i'm needing the factory engine harness for the tpi motor.my 92 z28 had a small fire. so how much for yours???
Old May 6, 2009 | 01:53 AM
F-Body_Fetish's Avatar
Car: 1984 Camaro Z/28
Engine: 350 SBC
what shape are the orange turn signal lights in the front in? specifically the pass. side one. also, does it have fogs? what about an antenna? how about the radio bracket, that metal thing that the radio and heater controls bolt to. also looking for those rubber feet that the rad sits on.
Old May 6, 2009 | 05:52 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
keep in mind yours is speed density while this 87 is a maf car.
are the tie rods, idler arm, and steering link in good...ie not bent shape?
Old May 6, 2009 | 06:35 PM
i know,thats why i want the computer and everything to make mine mass air! i dont know why chevy stopped putting them on it to begin with...
Old May 7, 2009 | 09:04 PM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
What exhaust do you have?
Old May 8, 2009 | 06:40 AM
lee33lyn's Avatar
Car: 84 Z28
I think it has flowmasters, but I'll have to look when I get back from the beach.
thanks Lee
Old May 8, 2009 | 06:45 AM
lee33lyn's Avatar
Car: 84 Z28
I want to sell the dist,ecm, and engine harness together for 150$
Old May 8, 2009 | 06:47 AM
lee33lyn's Avatar
Car: 84 Z28
idler arm and suspension stuff is all fine. It took a hit on the top left corner and bent the frame a little.Its just more to fix the car than its worth. Its a shame!
thanks Lee
Old May 8, 2009 | 06:51 AM
lee33lyn's Avatar
Car: 84 Z28
it has the fog lights and turn signal and radio brackets. This car is 100% complete. The antenna is there but I think its bent and won't go up and down.Its a powered antenna.
thanks Lee
Old May 8, 2009 | 06:53 AM
lee33lyn's Avatar
Car: 84 Z28
thanks Lee
If anybody wants this car complete. Let me know. I even have the parts to fix it and haven't started tearing it down.
thanks Lee
Old May 10, 2009 | 06:33 PM
Shmangles's Avatar
Want a title? Post!
Car: 1988 Iroc-Z
Engine: 5.7 L 350
Axle/Gears: Posi
i need the tpi distributor cover and bolts how much for those?
83201
Old May 10, 2009 | 07:05 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
That posi diff that you got, what gears are they and is it drum brakes.
Old May 10, 2009 | 09:15 PM
YanksHeels1's Avatar
How much for the motor and trans?im right outside of winston salem.
Old May 10, 2009 | 09:52 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
What type of steering box does it have? regular or quick ratio? Pm me with info pics and a price shipped to 08872 im very interested!
Old May 10, 2009 | 10:49 PM
relic87239's Avatar
Car: 1988 Chevrolet Camaro
Engine: In the market
Axle/Gears: 2.77
interested in the headliner, dash pad, door panels. What condition are these in? any pics?
Old May 11, 2009 | 08:05 PM
88IROCNM's Avatar
Want a title? Post!
Do you have the Heads? Casting #'s?
Old May 11, 2009 | 08:07 PM
lee33lyn's Avatar
Car: 84 Z28
rear gears are 3.42 with posi and drums
Old May 11, 2009 | 08:11 PM
lee33lyn's Avatar
Car: 84 Z28
I haven't tore into the car yet.and the head casting numbers are under the valve covers, I'll try to look in the next view days
Old May 11, 2009 | 08:12 PM
lee33lyn's Avatar
Car: 84 Z28
I'm not sure what steering ratio , how do I tell?
Old May 12, 2009 | 07:14 PM
wxhitmanxw's Avatar
Car: 1987 Iroc
Engine: 5.7
Transmission: TKO-600
Im interested in the headliner and sunvisors could you send me some pics? wxhitmanxw@yahoo.com
Old May 13, 2009 | 12:42 AM
petko0's Avatar
Engine: built 350 TPI
im intereste in the tranny, rear end, fan and trunk door. petko0@yahoo.com
Old May 13, 2009 | 06:20 AM
lee33lyn's Avatar
Car: 84 Z28
I'll send some pics this afternoon
Old May 13, 2009 | 09:06 AM
so how much u want for the computer,engine harness and mass air meter??i also need the factory air box,including the main bottom that sits in the radiator support... thanks
Old May 13, 2009 | 01:45 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
what kind of steering wheel? IROC or aftermarket? if its IROC what kind of shape, can i get pics and price? have stock fog lights? condition and pics? PM pics here or send to ksdooley@cableone.net.
thanks
Old May 29, 2009 | 10:43 PM
1quik4's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
Did you sell the mass air meter?
Old May 30, 2009 | 07:23 AM
lee33lyn's Avatar
Car: 84 Z28
no I still have it
Old May 30, 2009 | 07:43 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
what about my request?
Old May 30, 2009 | 08:23 AM
1quik4's Avatar
Axle/Gears: 3.73's
Take $50 shipped for it??? Let me know. If yes, whats your Paypal?
Old Jul 13, 2009 | 09:43 PM
jp71ss's Avatar
Want a title? Post!
Does the car have a salvage title? How much for the whole thing? Im in Martinsville.
Old Jul 14, 2009 | 06:37 AM
lee33lyn's Avatar
Car: 84 Z28
title is clear. I'd take 500$ you pick up
Old Jul 15, 2009 | 08:54 PM
yamban's Avatar
Car: 1985 Z28
Is the headliner available to buy? If so whats the condition on that,
Old Jul 15, 2009 | 10:26 PM
RIPT 87 IROC-Z's Avatar
Want a title? Post!
Car: 87 Camaro IROC-Z
Transmission: 700r4 shiftkit
Axle/Gears: 3.23 9 bolt
do you still have the door panels, rear speaker covers, headliner? pics to Spud612b@aol.com carpet(front particularly) pics too if in decent shape.
Old Aug 4, 2009 | 10:11 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
does it have the daul fans and fan relays??
Old Aug 4, 2009 | 09:34 PM
  #42
hdxl92's Avatar
Sent you a PM
Old Aug 9, 2009 | 01:25 AM
  #43
iroc_patron's Avatar
If the motor is still around, I'm looking for a stock crank pulley, if its the one with 2 vbelts and a 5 rib for the crank, w/p, and alt.
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
