Stock ZZ4 pushrods
Old May 11, 2009 | 07:04 AM
Wildebird's Avatar
Stock ZZ4 pushrods
Set of ZZ4 pushrods, 3000 miles on them, perfect condition. Make an offer.
Old May 11, 2009 | 10:48 PM
mrtater99's Avatar
Car: 89 RS.. 91 1/2ton 1500
Engine: 305 tbi
Transmission: 5 speed manual
Re: Stock ZZ4 pushrods
What is the length on them, stock .100 over , .200 over?
mrtater
Old May 12, 2009 | 06:55 AM
gmtofd's Avatar
Measured roller crate motor pushrod lengths, such as these to be about 7.200 inches. The actual measurement was at 7.194.
Old May 12, 2009 | 07:29 AM
Wildebird's Avatar
Heres the specs:
GM#:10241740
Material: 1010 steel
Diameter: 5/16"
Length: 7.122"
Usage: Hydraulic roller
Description: (1) Heavy-duty .060" wall, standard length. For use in 2nd design ZZ-series engines without guide plates.
Old May 13, 2009 | 04:52 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
THEY ARE GREAT RODS. GOT A SET OF THEM WITH MY ZZ4 CAM - THE BEST. SOMETIMES ALL THAT R&D REALLY WORKS.
sorry - did not see that i was shouting.
Old May 13, 2009 | 06:43 AM
gmtofd's Avatar
The set out of a ZZ3 mtr measured 7.194. Maybe the ZZ4's are different pushrods?
Does not quite make sense being as they both use the same cam, unless the ZZ4 uses a different leght lifter, which I doubt. Used a set of harden aftermarket pushrods in my ZZ3 mtr and they measured 7.200.
Assembled a 350 Vortec roller mtr and used shorter lenght Comp push rods at 7.150.
IMO. 7.122 inch for those ZZ4 rods is a typo.
Old May 13, 2009 | 06:48 AM
Wildebird's Avatar
The zz-zz3 did have different pushrods. I forget the part number for the older stuff but they were for guide plates. The ZZ4 has self guided rockers which is why they changed them. From what I read both GM products are good. As for the length difference, not sure. Maybe different heads?
Maybe the length is a typo but its off GM's site.
Old May 13, 2009 | 11:24 AM
gmtofd's Avatar
This ZZ3 mtr had wider than normal push rod guide plates, along with self aligning rockers.
Always thought that ZZ4's used the same valve gear, (except for valve springs/retainers) set-up.
They both use the 113 Corvette D exh port head.
Old May 13, 2009 | 01:01 PM
Wildebird's Avatar
Not really sure on that one. I got my info from crate engine depot and thats just what their site says.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
