[IL] Parting out 87 Formula.....
Old Jul 2, 2009 | 09:40 AM
ZAKS62's Avatar
Car: 1987 Monte Carlo SS Aerocoupe
Engine: 305 H.O.
Transmission: 700-R4
Axle/Gears: 3:73 Posi
I recently bought an 87 firebird formula that the previous owner had deconstructed. He literally removed every nut bolt and screw from the body and interior, and its all sitting in boxes and piles and needs to go. The car is now a rolling shell with good title, has the stock 305 carb motor, and still has the rearend and suspension intact. Its a borg-warner 9bolt discbrake posi, and its supposed to be ws6 suspension. But Im trying to verify that. Basically everything is there minus the hood, pass. door, and stock front nose. There is a Trans Am/GTA nose here though with the correct support brackets. Email or call(best way) with needs. Absolutely NO SHIPPING on bigger items i.e. interior, suspension, body panels, etc.
Car has grey and black interior
-140 speedo
-factory speaker amp and dash control for the Gain and stuff
-9bolt disc posi rear
-2 good 91-92 fenders w/ big vents behind wheelwells
-transam/gta nose w/ support brackets
-2 sets of headlight motor assy
-a/c parts
-305 carb long block(milage unknown but does turn over and did run)
-ws6 suspension???
Or buy the whole thing w/ title $500.00!!!
Lemme know... (217)493-4751 or zkeeter1@stu.parkland.edu
Old Jul 6, 2009 | 09:26 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Parting out 87 Formula.....
know what gear is in the rear? how much were you looking to get for it
Old Jul 6, 2009 | 11:59 AM
ZAKS62's Avatar
Engine: 305 H.O.
On the rearend, previous owner says its a 3:42, but stock I believe they are 3:23. I havent got to open it yet. Either way, wanting $200 complete disc to disc. I will try to update as soon as I know the ratio.
Old Jul 6, 2009 | 03:15 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
Do you still have the speedo? Very interested! How much shipped to 43147?
Old Jul 6, 2009 | 03:23 PM
ZAKS62's Avatar
Engine: 305 H.O.
On the speedo, I can do $75 shipped
Old Jul 7, 2009 | 09:26 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
interested in rear, any pics? where is monticello ? I live near o hare
Old Jul 7, 2009 | 01:32 PM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
With 9 bolt rears it would probably be 3.27 or 3.45
Old Jul 8, 2009 | 08:17 AM
ZAKS62's Avatar
Engine: 305 H.O.
I dont have any pics right now. The rear will be out tonight, cause the body is going to the junkyard. Once its out I will check ratio for sure. Being that it has supposedly been rebuilt, it could be any ratio, who knows. But I will update as soon as I know. Also, Monticello is 20min west of Champaign-Urbana, IL on I-72. Zip code is 61856 if you wanna get iternet directions, or use gps.
Old Jul 8, 2009 | 08:22 AM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
I could use the tailshaft and torque arm bushing...i have one that does not have that provision that i could send back to you so the tranny would still be whole.
Old Jul 8, 2009 | 10:48 AM
ZAKS62's Avatar
Engine: 305 H.O.
Send your tailshaft housing plus $25 to me:
Zac Keeter
702 N. Charter St.
Monticello, IL 61856
As long as it checks out good, I will send you one. I have a few(3 or 4) trannys here out of thirdgens with the right tailshaft and torque arm bushing. Lemme know what you wanna do. (217)493-4751
Old Jul 8, 2009 | 11:24 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Any chance it had an aluminum driveshaft and, if so, how much shipped to 44077?(USPS should be less than $20)
Old Jul 8, 2009 | 11:42 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
what size are the swaybars? Also how much for both of them shipped to 30041?
Old Jul 8, 2009 | 03:14 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Got the intake assembly?
Old Jul 9, 2009 | 01:43 PM
ZAKS62's Avatar
Engine: 305 H.O.
89IROCZ28>>> Drive Shaft is steel, not aluminum in this one sorry...
bmxerboi221>>> Front is 35ish mm and rear is 24mm, asking $75 for both shipped to your address. Lemme know.
Saber>>> Was 305 carb motor, I dont have the intake that came off it, but I have other GM qjet intake manifolds if thats what you are looking for. Lemme know.
Old Jul 9, 2009 | 10:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
you pull that rear yet? thanks
Old Jul 10, 2009 | 06:42 PM
NUKEM's Avatar
Car: 1991 GTA Trans Am
Engine: TPI
Transmission: T-5 World Class
Axle/Gears: 10 Bolt 3:45
Do you have the wiring harness for the car?
Old Jul 11, 2009 | 08:20 AM
ZAKS62's Avatar
Engine: 305 H.O.
Ok, the rear is out yes, it is a 3.27 gear and ring teeth look good. It does however have some evidence of someone being in there before, I dont know how recently. And whoever was left some bolts loose. Where the bolts for the ring gear are, there is a smaller ring of bolts as well and some of the have backed out. Very usuable from what I can tell. still functions and even locks in posi just by hand. But I would suggest reduilding just in case. I would at least have it looked at by someone who knows more before using it, I would if I were keeping it.
As for the harness, there are wiring sections everywhere, the kid that disassembled the car cut everything into sections. It all has enough wire left for connecting back up, but its just a mess.
Old Jul 15, 2009 | 12:37 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Sorry so long to respond dude...i found one locally dirt cheap but i still need the torque arm mount cause the one for the 5speed is different. How much for just the mount and bushing?
Old Jul 17, 2009 | 08:56 AM
ZAKS62's Avatar
Engine: 305 H.O.
FROZER>>> Rearend has been disassembled and repaired. I had the differential inspected, both ring and pinion gears, and spider gears and internals of the diff. They ofcourse have wear because they are used, but nothing excessive, and no damage to and components, there are some scars on the diff case from a previous issue of some sort. All in all, very usuable used rearend. $150.00 bottom dollar. Lemme know
Old Jul 25, 2009 | 11:07 AM
ZAKS62's Avatar
Engine: 305 H.O.
TTT
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
