[NJ] TPI setup
TPI setup
TPI setup 350ci speed density
Intake
Injectors(checked and flowed by cruzin performance)
Adjustable FPR
Fuel gauge on rail
Plenum,tubes
Throttle body(stock)w/airfoil
All sensors
K+N filter that goes on TB
Distributor
Ecm no prom
Painless harness to install in any car I had it in a blazer but now the truck is gone and im getting rid of this stuff.Harness wires are not all cut up or shortened.
Harness #60103
Would like it all to go together
Can ship all together its heavy
$400.00 plus shipping
Intake
Adjustable FPR
Fuel gauge on rail
Plenum,tubes
All sensors
Distributor
Ecm no prom
Harness #60103
Last edited by kustom71; Jul 24, 2009 at 09:14 PM. Reason: forgot to add its for a 350
Car: 86 Z
Engine: 383 Mini Ram
Transmission: TCI Street Fighter 700R4
Re: TPI setup
I need the air foil. Who made it? TPIS? or is it one of those plastic Holley's
Re: TPI setup
I would rather not part it out but may if there are no others interested!
It is 400 or best offer
I might be open to trades my other projects include a 84 chevy pickup and 71 chevelle
Whatcha gots?
Yes the airfoil is a TPIs piece or street and performance(not plastic)
Whatcha gots?
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TPI setup
For what year is the ecm and wiring harness because i am looking for a set up like that but for my 91
Car: 1990
Axle/Gears: stock
Re: TPI setup
you are in the ballpark. i paid 500.00 including shipping for mine and it is in good workable condition.
the only difference is that mine had the stock tpi wires and computer.
you are not asking too much.
but money is tight.
try e-bay.
but money is tight.
try e-bay.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TPI setup
Did you did a tpi swap in your car or did it come with a tpi i wanna do that swap is this all i would need to put it in my camaro. I see you live in CA you could probably help me.
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: TPI setup
im making a trip to jersey soon what else would i need to convert my car to tpi? i have a 91 305 tbi. will i have to change any pulleys? is it pretty much a take off put on job?
Re: TPI setup
First JR350tpi
It is a 91-92 speed density setup
The harness is from PAINLESS WIRING and is made so someone could put TPI on any small block chevy in any year car.
I did this to my 86 chevy blazer 4wheel drive
It ran great,so great that the trans was on its way out(i didnt know bought the truck thaway)
Guess what happened(BOOM)
In the end it was all rusted out anyway so I pulled this stuff back out.
QUICKKRIS2006:
The only part I dont have is the MEMCAL for the computer
YOu would need to get one they are for sale online or you could burn your own
This setup does not effect any pulley setup as far as I know I used the stock pulley setup on the blazer I had
I think the only time you mess with the pulleys is going to serpentine setup!
QUICKKRIS2006:
Engine: ls1 soon
Re: TPI setup
ok sounds good i will try to come up with the money but if u decide to part out the only parts i need are the wireing harness and computer
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TPI setup
Would i still have the ac and other things because i have seen that those harness are just for the older cars and is $400 with everything and shipped
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TPI setup
OK just let me try to complete the money cause aint got the $400 right now but i am very interested if i sell my tpi i will get it. Can you also send me more pics. to castrorodolfo28@yahoo.com
Thank you
Thank you
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TPI setup
Right now i have $300 saved up but i just wanted to check that how would i be able to run both harness my stock one from the tbi and the tpi one. For i could have the A/C in my car
Re: TPI setup
Im not sure how to change over from a TBI setup to TPI setup.
The painless harness I have has all wiring for the engine so my guess would be you would reuse your other wiring as far as lights,A/C,starter and use the harness from me to run the motor(control the injection).I do have the original manual for the painless harness that I will include with the parts.In it tells how to hook everything up.
Sanjay
Aug 12, 2015 03:41 PM
