[KS] SOLD
Old Aug 31, 2009 | 10:23 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
SOLD
SOLD
Old Sep 1, 2009 | 12:38 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Re: JET chip: Stg2 for 89 305 TPI auto
would this work for a 91 305 TBI auto and what does it do?
Old Sep 1, 2009 | 09:01 AM
thewizard's Avatar
^It would not work for that application. It should work for any 305 auto with the MAF TPI from 87 to 89.
Basically it changes the fuel and timing curves along with some parameters like fan control.
Old Sep 1, 2009 | 04:30 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Isn't the 89 a speed density car which would mean it wouldn't work for the older MAF cars?
Old Sep 1, 2009 | 11:53 PM
thewizard's Avatar
nope. SD was 90-92.
Old Sep 2, 2009 | 12:04 AM
Car: 1987 IROC-Z
Transmission: TH350
Ok, i wasnt sure if it was 89 or 90 when the switch was made but i figured i would ask to be sure. Do you have to use their fan switch when you use their chip? Would the chip still work with an upgraded cam and ported heads and intake? Did you notice any difference?
Old Sep 2, 2009 | 12:12 AM
thewizard's Avatar
fan switch: no
I definitely noticed a difference, and my setup was properly modified as they suggest for a Stg 2 chip.
It would be much better than a stock tune file for the mods you listed.
I just looked and this part is $210 new; damn I put my price too low. oh well
I'm going to call Jet in the morning and ask about the model year compatibility just to make sure.
Old Sep 2, 2009 | 12:16 PM
thewizard's Avatar
JET was not much help.
Anyway, on second thought, I don't think 87' models had VATS and they have a cold start provision as well. So, this chip won't work for that year. I may work in an 88' though.
Old Sep 6, 2009 | 10:07 PM
thewizard's Avatar
$45 shipped?
Old Sep 29, 2009 | 11:44 AM
thewizard's Avatar
ttt
Old Oct 1, 2009 | 08:23 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
Originally Posted by thewizard
ttt
you do 40 shipped if so its mine 28676 thnx
Old Oct 4, 2009 | 07:33 PM
c4ta's Avatar
Car: 89' GTA,98' z28
Engine: 350tpi/ls1/ls6
Transmission: 700r4/4L60e
Axle/Gears: BW 3.27/3.42
part number is dif for my 88' TA otherwise i would buy it.
Old Oct 4, 2009 | 11:07 PM
thewizard's Avatar
I'm not sure if it matters or not; the computer still has the parameters for those systems, and if the chip doesn't have a reason to modify them everything should be kosher.
Old Oct 7, 2009 | 09:13 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
is this sold, if not i will buy for sure
Old Oct 10, 2009 | 09:06 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
payment sent
92rsvortec350
19
Oct 9, 2015 09:39 AM
bjpotter
Oct 2, 2015 09:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
Night rider327
Exterior Parts for Sale
Sep 25, 2015 04:23 AM
pmacfadden
Sep 17, 2015 01:06 PM
