Nice cam w/ LIfters, 75 shipped
http://www.summitracing.com/parts/CR...1/?image=large <--- Camshaft, brand new lubed it up, set in engine, changed set up, also included are some new EPW lifters VERY nice cam, well rounded Camshaft
92 shipped?
92 shipped?
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Nice Cam w/ Lifters also NIB Earls SS braided lines!
I'm interested in the brake lines, but I'm broke at the moment.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I'm interested in the cam. Would you do $65 shipped on it?
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
nice cam....imo
bias... cause I have the same one in my boat
DD said 310hp and amazing 380tq
with vortec heads both would inprove
2 cents
2 cents
Car: 84 Camaro Z28
Engine: 355 Carb
Man to bad that cam doesn't work with computer control car. If it did I would of get already.
Car: 86 Trans am
Engine: workin on a 383 for it!
hey would you happen to be able to have a picture of the condition of your cams and liferts?
Lifters brand new in box, and Cam was lubed up set in engine and never ran, i pulled it out and cleaned it off and put CLR on it.
I put it back in a spare cma box i had and taped it shut
Re: Nice cam w/ LIfters, 75 shipped
rikenfraken frackenriken............................................ttt
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Are you okay??? bump for a good deal and a guy who I believe is self medicating himself
Cam Style
Hydraulic flat tappetBasic Operating RPM Range
1,800-5,600Intake Duration at 050 inch Lift
216Exhaust Duration at 050 inch Lift
228Duration at 050 inch Lift
216 int./228 exh.Advertised Intake Duration
272Advertised Exhaust Duration
284Advertised Duration
272 int./284 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.454 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.480 in.Valve Lift with Factory Rocker Arm Ratio
0.454 int./0.480 exh. liftLobe Separation (degrees)
112Intake Valve Lash
0.000 in.Exhaust Valve Lash
0.000 in.Computer-Controlled Compatible
NoGrind Number
H-272-2
Car: 1989 TPI Formula, 1984 MCSS
Please clarify.
Crane brand cam? New, lubed, cleaned and re-boxed?
Engine Parts Warehouse lifters? New, never used?
Yes, i bought it brand new, lubed it up to set it in my engine, it sat in my engine, and i took it out because plans changed, i cleaned all the lube off it, and sprayed it with some CLR, and it was reboxed in a Old Cam box i had laying around, not original box
and yes EPW lifters, brand new, never lubed up or aything, i just opened the box and took one lifter out and looked at it, and put it back in the, they never had fluid out or ever in the bore, or naything.
