[NY] (2) 4th gen posi rears with disc brakes, LT1/LS1 for sale NY
Old Dec 28, 2009 | 08:44 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
all SOLD
Old Jan 6, 2010 | 03:58 AM
Rocksiroc's Avatar
Re: (2) 4th gen posi rears with disc brakes, LT1/LS1 for sale NY
Im very interested in the 2000 rear
pls pvt me
I pvt messsaged u
Old Jan 9, 2010 | 07:54 AM
drptop70ss's Avatar
Car: way too many
TTT
Old Jan 9, 2010 | 09:28 PM
Night Stalker's Avatar
Car: 1987 IROC
Axle/Gears: 10-Bolt 3.73
Originally Posted by drptop70ss
I have two complete 10 bolt posi rears for sale, both complete end to end with disc brakes, working posi units, and 3:23 gears.
-first rear from a 93 trans am, unknown miles as it was not original to the car, $250 complete
-2nd rear from a 2000 Z28 camaro, 110K miles, $350, has the larger rear disc brakes and zexel posi unit.
These are 4th gen rears and will bolt into a 3rd gen no problem, they are 2" wider on each end which makes them perfect for running later model corvette/Z28/Trans am wheels on your 3rd gen without spacers.
NO shipping, pick up in NY zip 12538.
I'm interested but just so I understand, if I put my stock 87 IROC wheels back on they would stick out of the quarter panel by about 2"?? What is the correct backspacing to use so the wheels tuck under the car the way they should?? Other than that it's a complete bolt in??
Old Jan 10, 2010 | 12:29 AM
drptop70ss's Avatar
Car: way too many
Correct..if 3rd gen wheels are used they will stick out 2" on each side. If 4th gen F body or later model corvette wheels are used they will fit as factory and not stick out. The rear itself is a bolt in.
Old Feb 3, 2010 | 07:45 PM
drptop70ss's Avatar
Car: way too many
TTT both rears are removed from their donor cars and ready to go.
Old Feb 4, 2010 | 02:56 PM
travrock's Avatar
Car: 1991 Bird
Engine: Goodwrench 4bolt 357 bore vortec
Axle/Gears: 10 bolt posi disc w/3.23
but to use 4th gen wheels up front you will need adapters,to fit over the hub.
Old Feb 4, 2010 | 07:17 PM
drptop70ss's Avatar
Car: way too many
I dont know if that is true or not, but I have both LT1 and LS1 front brake assemblies available if anyone wants to upgrade the front at the same time.
Old Mar 1, 2010 | 08:55 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
2000 rear still for sale?
Old Mar 1, 2010 | 09:36 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Hey Dave, just to try and help your sales a little, the wheels won't stick out 2 inches from the wheel well, but 2 inches farther out from the outer edge of where the tires are now, so since they are an inch and a half in from the wheel well, they will be perfectly flush to sticking out slightly with the '93 axle, and the 2000 axle is actually slightly shorter, at an inch and a half wider on each side, so that 3rd gen wheels will be nearly perfectly flush with the fender...the following picture is my 3rd gen firebird with 16" formula wheels and a 2000 rear axle, you can see that it's flush, and to make sure it doesn't rub you can either round the inner edges of the fender or use air shocks like i have. Also the 2000 rear axle will require at least 16" wheels, where i believe certain 15" wheels will be able to fit on the '93 axle. As far as front brakes, on a third gen spacers will be needed regardless. If you go LS1 brake upgrade in the front, you probably can get away with 1/2" less of a spacer because the new disk on hub assembly will be 1/2" farther out than factory. Hope this helps clarify for prospective buyers!
http://i283.photobucket.com/albums/k...m/P3140203.jpg
Old Mar 1, 2010 | 02:25 PM
drptop70ss's Avatar
Car: way too many
Thanks for the info, helps a lot, didnt know the 2000 rear was narrower than the 93.
The 93 rear is sold, but the 2000 rear is still available. It is a 3:23 posi with the zexel posi unit, $300 cash takes it.
Old Mar 22, 2010 | 06:52 PM
drptop70ss's Avatar
Car: way too many
all SOLD
Old Mar 22, 2010 | 07:00 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
TTT one more time before the 2000 rear gets packed up, can deliver to the following swap meets
spring bristol ct
spring stafford springs ct
spring englishtown NJ
When are the meets in ct? i live close to both of them.
Im interested in the rear, and you said its a 3.23 rear?
Old Mar 22, 2010 | 07:15 PM
drptop70ss's Avatar
Car: way too many
all SOLD
Old Mar 23, 2010 | 01:20 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Wish you were more towards Rochester NY, I'd pay cash ASAP for it.
Old Mar 23, 2010 | 05:17 PM
jpgreen10494's Avatar
Car: 90 Firebird, 96 caprice 9c1
Engine: 305tbi, lt1
Transmission: 700R4, 4l60e
Axle/Gears: 2.73, 3.08
im interested in the 2000 rearend.. got pics???
Old Mar 25, 2010 | 08:41 PM
drptop70ss's Avatar
Car: way too many
sorry both rears are sold.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
