7.5 rear 4.10 gears, zexel, posi aluminum cover and bearings
Old Jan 3, 2010 | 01:31 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
Selling stuff for my 7.5 rear. I went a different route.
GM 4.10 ring and pinion used for about 10k miles
zexel torsen gear type posi carrier from a late model camaro bought it used, mileage ?
cast aluminum gusset diff support cover from summit used
new axle bearings and seals
solid pinion spacer with shims
I would like to get 400 for everything but feel free to make offers on any of the stuff separately
Email DanGT86@Gmail.com
call 314-600-8453
or send me a PM
Thanks,
Dan
Old Jan 3, 2010 | 03:59 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: 7.5 rear 4.10 gears, zexel, posi aluminum cover and bearings
interested in the alum cover and the solid pinion spacer (don't need the shims though).
does the summit cover also have the bearing cap support?
lmk how much shipping to plattsburgh ny 12901 is. thx
Old Jan 3, 2010 | 05:36 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
the pinion spacer needs the shims to work, how would you set your pinion depth without it? Il offer you 25$ shiped to canada on the pinion spacer, summit wants 16.95 for it brand new, and shipping by usps shouldnt be more than 6-7$. LMK
Old Jan 3, 2010 | 05:41 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Interested in the gears and possibly the cover. $100.00 shipped?
Old Jan 3, 2010 | 08:08 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
PM sent to OWNOR
Yes the cover does have the Bearing cap supports. They are the setscrew locknut type that press on the carrier bearings.
1986Z28OWNER
I can probably do 25 shipped for the spacer if ownor does not want it.
KWIK84
The cover may be spoken for also but the gears will still be available. Did you mean 100 shipped for the gears and the cover or just the gears?
Old Jan 3, 2010 | 09:07 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Both, let me know when you find out about the cover, still interested in the gears though as long as they are for a 3 series carrier.
Old Jan 4, 2010 | 11:56 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
How much are you looking to get for the Posi shipped to 22602?
Please PM me.
Old Jan 4, 2010 | 04:12 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
JTNKTZ
The posi may be spoken for I should know tomorrow after lunchtime.
KWIK84
I cant do 100 for the gears and cover together but if you end up buying them both I would reduce the price a little since it would save me some trouble packing stuff up and shipping
I wanted to get 100 shipped for the gears but that may be a little ambitious.
I dont remember what series they were. I thought they were series 3 because I always remembered the series 2 4.10s looking really thick. Now I am second guessing that
Does anyone know how thick the series 2 or 3 4.10 gears should be? This ring gear is 1-7/16 thick and has a little boss that looks kinda like one of those ring gear spacers so maybe it is a 2. Here are some close-ups that may help identify as I cannot seem to find any good info and I dont have another set to compare them to. Sorry to post an add without knowing that first.
Old Jan 4, 2010 | 09:28 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
pretty sure they are series 3 they were on a carrier that had 3.23s on it before the 4.10s.
Old Jan 5, 2010 | 09:33 AM
ownor's Avatar
Engine: LS1 / L03
maybe because i already have the shims? the solid pinion spacer is just a replacement of the crush sleeve collar, right? if not, i was thinking of something else and don't need it.
Dan, replied your pm about the cover. Thanks for the info.
Old Jan 5, 2010 | 04:04 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
OWNOR
PM sent
To clear up any confusion on the spacer it is a solid replacement for the crush sleeve and should have nothing to do with the pinion depth unless you really screwed something up. The shims are only needed when using the spacer and are for setting the proper bearing pre-load because the crush sleeve usually takes care of that by the compressing when the nut is torqued. Since the spacer does not crush the shims determine the pre-load or "smash" on the bearings when the nut is tightened.
Status on other stuff:
I think the cover and probably the spacer are sold
I still have the
Gears $100 shipped
posi $120 shipped
bearings and seals $? hopefully someone will give me few bucks for them to be included with one of the other sales.
Old Jan 11, 2010 | 07:47 AM
ownor's Avatar
Engine: LS1 / L03
who would've thought... i might want your gears now, too :bash:
could've saved some on shipping but oh well. so they are true GM gears with 10k you say, and 3 series right?
Old Jan 11, 2010 | 02:15 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Does the Zexel fit any 7.5 or is it specific to late model units...possibly with anti-lock brakes?
Old Jan 12, 2010 | 08:56 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
wesilva
sorry the posi is gone
Ownor
As far as I can tell the gears are GM and series 3.
I remember the guy I bought them from said they were GM but I have no real way to prove it. He had them in an impala and had to change carriers to go from 2.73s or 3.08s to these. That would make sense that he would have gone from the 2 to 3 series to use them.
if they were series 2 they would be a lot thicker.
The ring gear has this stamped on it:
10090-gm7.5-410-10x41
I didnt get any results searching that number.
Sending you a PM
Old Jan 16, 2010 | 06:42 AM
ssgtgaines's Avatar
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
do you have any of this stuff left
Old Jan 17, 2010 | 02:27 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
do u still have the cover i couldnt find a clear answer
Old Jan 18, 2010 | 06:56 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
Sorry the cover is gone.
The only thing left is the gears and I am awaiting payment on them so they are most likely sold. I will update if it falls thru.
THanks everyone.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
