sold
Old Jan 15, 2010 | 12:50 AM
zippinz's Avatar
Car: 1986 CAMARO Z28 +++
Engine: 496
Axle/Gears: 456
sold
sold
Old Jan 15, 2010 | 06:49 PM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
Re: Camaro / Firebird T5 V8 bellhousing ceramic coated
bump
Old Jan 16, 2010 | 08:05 AM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
ttt
Old Jan 17, 2010 | 12:43 AM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
It blows me awy that I still have this..I have seen guys on here pay 100 + for old nasty ones.
Old Jan 17, 2010 | 07:42 AM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
I'd rather pay $50 for a nasty one and clean it up. Ceremic coating doesn't do much for me on a bellhousing. A $50 one also does the same thing as one 2 1/2 time the price.
Try Ebay, this type of thing is like a gold when it is veiwed by a larger audience.
I realize this isn't anything you probably want to hear, but most guys running a T5 are on a budget.....that is why they are running a T5.
Old Jan 17, 2010 | 08:10 AM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
we if you did some research on what ceramic coating will do ..maybe you would think different..Then again maybe not...but you know what opinions are like....And also t5's are not just for budget builds.
Old Jan 17, 2010 | 08:18 AM
87SSTPI's Avatar
Agreed about the opinions.
The bellhousing isn't exactly where the problems arise in a T5 setup though.
Sorry for the derail......good luck on your sale.
Old Jan 17, 2010 | 08:23 AM
lvbg1435's Avatar
Car: 1985 camaro Berlinetta 88 firebird
Engine: v8
Transmission: 4 speed
sweet bell housing i like the good old plastic bell houseing tho less pounds on the car the marryer
Old Jan 17, 2010 | 08:24 AM
lvbg1435's Avatar
Engine: v8
you should sale this in few day or maybe a week their are buys on here looking for this stuff
Old Jan 17, 2010 | 08:38 AM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
Your right the problem with t5's are People buy 20 year old trans dont do anything to them beat the hell out of them and they blow, Then say they are junk. If you have then rebuilt and done right they are good trans
Old Jan 17, 2010 | 08:46 AM
lvbg1435's Avatar
Engine: v8
you know your 100% right i dont want to go there but umm thos so call hondas and imports their trannys go so do their motors be for 100k so the import guys well are no better then gm or ford people sure their 4 banger might get better gas but it not ment to race with out mods coast more to mode a import then a mussel car sure i can put a trubo on a camaro and corvettes and firebirds and blow them out of the water
Old Jan 17, 2010 | 09:27 AM
87SSTPI's Avatar
All right. I wasn't going to try and keep posting in here, but you know what.....
A T5 isn't weak because it's 20 years old, improperly rebuilt, or just because a person doesn't know what they are doing. The T5 is weak because it was NEVER meant to be extremely strong. Therefore the housing itself wasn't/isn't made to handle the stress off high torque/HP numbers. Doesn't really matter what you do to them internally, they will still allow flex within the housing/case which in turn causes problems. Sure, you can make them 'stronger' with better internals, but to imply that they are weak only because of the person working on them is unqualified or the age of the trans is BS.
Also, I understand exactly what ceramic coating does. I just think there are some things that don't need ceramic coating. If you think your "Heavy Duty" bellhousing isn't going to break over one that did simply because it was ceramic coated well........
The only reason I posted in here is because you started this ad on the 15th(2 days ago) and bumped it 3 times in less than 2 days with an impatient comment about how people pay "100 + for old nasty ones" so I figured I'd chime in. Maybe some do pay $100 for "old nasty ones", but MOST people don't.
I really had no intention in derailing your entire thread, but don't treat everyone like they are all retards because your part hasn't sold in 2 days.
I assure you I am done posting in this thread.
Old Jan 17, 2010 | 11:03 AM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
First off I NEVER said it made it stronger with the ceramic coating. And I dont care what trans or part is is if you beat it enough it will break.
Second, This isnt the first time I have had this listed on here.
Third, This is why I stoped posting on here because guys like yourself have nothing better to do with your time then to **** with peoples threads just to start **** because your a cheap *** and want everything for nothing.
ANd last I never implyed any one was a retard as you are implying as to me as I know nothing and you are the king of know all
If you click on a thread and in your opinion its not what you want to see price or part you want to derail,hijack what ever you want to call it
Old Jan 18, 2010 | 05:47 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
zippinz, not trying to be a d*ck, i'm just curious and still learning, and maybe an explanation like this will help you sell it: what does ceramic coating a bellhousing actually do? i know the coating is used to keep high temperature inside or outside of something like exhaust ports or turbine parts, but i can't see the use of a coated bellhousing.
if you care to explain, thank you in advance
Old Jan 18, 2010 | 12:13 PM
zippinz's Avatar
Engine: 496
Axle/Gears: 456
Ceramic is mainly for the heat keeping temps down and also for appearance. In my opinion is there a big performance advantage doing a bell housing not really I did it because that's what I wanted.
Old Jan 19, 2010 | 02:55 AM
ownor's Avatar
Engine: LS1 / L03
ok thanks
free bump for you
92rsvortec350
19
Oct 9, 2015 09:39 AM
bjpotter
Oct 2, 2015 09:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
Night rider327
Exterior Parts for Sale
Sep 25, 2015 04:23 AM
pmacfadden
Sep 17, 2015 01:06 PM
