Parting T/A big items (GA)
1. hotchkis panhard- $60
2. Jegster lower control arms-$75
***3. spohn torque arm and crossmember for Th350- $250 (sold-pending funds)***
Item 4 sold! thanks!
5. spohn K member.. no spring buckets. solid motor mounts welded and bolted to k member. can leave on or remove your choice- $250
6. Northern Alum drop in radiator +2 12" puller elec. fans - $200
7. Almost new fuel tank.. Carb only- nonFI tank- $100
8. 9" housing bolt in w/ 35 spline axles 5/8" studs + 11" ford drum brakes $600
9. taillights great shape. $50
have pics upon request!!
thanks for looking
706-247-1626
thanks for looking
706-247-1626
Last edited by JUNKYTRANSAM; Jan 18, 2010 at 10:09 PM. Reason: $50 drop in price for torqe arm
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
Re: Parting T/A big items (GA)
where are you located and can i get pics of the frt struts and coilovers
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
the motor mounts, are two piece, correct? do you have the motor side mount? if so, how much?
Car: 1989 firebird
Engine: 383
Transmission: 6 speed
Axle/Gears: ford 9" 410
will you take 125 shipped threw pay pall?
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
You got a pic of this? What were you using for the lower a-arm? Stock?
Car: 83 t/a , 89 Formula
Engine: t/a-455 Olds, formula 305
Transmission: soon to be 4 speed, 700r4
Axle/Gears: 2.77, 3.23
thanks for looking
706-247-1626
thanks for looking
706-247-1626
Anybody heard from the OP...has not been on TGO since 2/11/2010
LT1Formula
20
Nov 14, 2015 12:02 AM
