2.8 v6 motor and tranny 5speed CHEAP
Old Feb 17, 2010 | 06:09 PM
G-4ce's Avatar
Car: 1989 RS
i have a 1989 2.8 engine and t5 that i will no longer need to to v8 swap. i was goin to keep it for a later project but it will just sit there for ever.. so i have chose to part it out im not asking much for anything just alittle for shipping and gas and time but anything you may need or want off this engine is up for grabs.
i also have a 1991 parts car and a tbi set up and ecm
Heads v6 (Sold)
Pace Setter Headers v6 (Sold)
Tensioner Pulley & Dizzy v6 (sold)
Old Feb 17, 2010 | 06:21 PM
pgmonster's Avatar
Car: Firebird Pro/Am
Engine: 5.0 TBI
Re: 2.8 v6 motor and tranny 5speed CHEAP
What about a steering column?
Old Feb 17, 2010 | 06:53 PM
G-4ce's Avatar
Car: 1989 RS
i can sell you the 1991 steering column whats your zip code
Old Feb 19, 2010 | 08:32 AM
G-4ce's Avatar
Car: 1989 RS
bump
Old Feb 19, 2010 | 03:47 PM
G-4ce's Avatar
Car: 1989 RS
I also have a set of pace setter headers there in really good condtion nothing wrong with them just dont need them anymore asking 75$
Old Feb 19, 2010 | 04:21 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
PM Sent
Old Feb 19, 2010 | 06:23 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Where Are you located? I want the Trans, peddles, and hydraulics
Old Feb 19, 2010 | 06:40 PM
G-4ce's Avatar
Car: 1989 RS
im in florida whats your zip
Old Feb 19, 2010 | 07:14 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
19401
Old Feb 20, 2010 | 12:19 AM
G-4ce's Avatar
Car: 1989 RS
T5 out of a 89 Camaro with a 2.8. Complete transmission, with bellhousing throw out bearing, clutch fork, crossmember, mounts, shifter, etc. Also comes with the 2.8 flywheel, pressure plate, and a slightly used clutch. but i dont think you want me to ship something like that its not light
Old Feb 20, 2010 | 02:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Does the engine have the serpentine set up? If it does, what shape is the tensioner pulley in?
Also, how much for the distributor? If you want to sell the module inside, that's fine. I have 2 of them, and I only need the dizzy body itself anyways.
Old Feb 20, 2010 | 04:51 PM
G-4ce's Avatar
Car: 1989 RS
yes it has the serpentine set up, its good and the dizzy is fine whats your zip
Old Feb 20, 2010 | 04:56 PM
G-4ce's Avatar
Car: 1989 RS
Old Feb 20, 2010 | 05:05 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I need the tensioner pulley (just the pulley, if it doesn't squeal like a banshee with the engine running), and my zip is 14482.
Old Feb 20, 2010 | 05:17 PM
G-4ce's Avatar
Car: 1989 RS
ok and the dizzy right? anything else?
Old Feb 20, 2010 | 05:35 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Nope. That's all.
Old Feb 20, 2010 | 05:36 PM
G-4ce's Avatar
Car: 1989 RS
ok so you want a serpentine or flat pully? cuz it has a flat on it right now but i think i have one laying around
Old Feb 20, 2010 | 05:38 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The pulley off of the belt tensioner. My tensioner(s, I have 2) are good but the bearings in the pulley are shot and, like I said before, it squeals like a banshee.
Old Feb 20, 2010 | 05:52 PM
G-4ce's Avatar
Car: 1989 RS
ok shipping is 15$ and i would like 25$ = 40$
for pulley, belt tensioner, and dizzy!
Old Feb 20, 2010 | 05:54 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Do you do PayPal? I can pay Monday.
Old Feb 20, 2010 | 05:57 PM
G-4ce's Avatar
Car: 1989 RS
ya jonathanecoffin@yahoo.com i will ship monday
Old Feb 21, 2010 | 05:28 PM
G-4ce's Avatar
Car: 1989 RS
I have a Ac Delco v6 alternator for an 89 its been manufactured recently it still has the sticker on it
Old Feb 22, 2010 | 11:35 PM
G-4ce's Avatar
Car: 1989 RS
bump
Old Feb 23, 2010 | 07:50 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Payment sent last night. Bump.
Old Mar 3, 2010 | 08:33 PM
G-4ce's Avatar
Car: 1989 RS
bump bump bumpaty bump
Old Mar 5, 2010 | 04:48 PM
crystal383's Avatar
do you have the master cylinder and hydraulics for sale?
Old Mar 5, 2010 | 07:54 PM
G-4ce's Avatar
Car: 1989 RS
yes but its pending
Old Mar 5, 2010 | 08:27 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Is the engine set up for the seventh injector in the back of the lower intake? If it is, I need the fuel rail (without the injectors or the fuel pipes)... I got rid of mine like an idiot and the long crank time is killing my battery .
Old Apr 10, 2010 | 10:32 PM
zeb87's Avatar
Car: 1987 Chevrolet Camaro RS
Engine: 3.1 MPFI
Axle/Gears: 4.10 Posi
Hey I just broke my alternator bracket, and I was wondering if you had the alternator brackets and the if you still had the belt tensioner arm. I don't need the pulley if you already sold it. Thanks.
Old Apr 11, 2010 | 10:17 AM
Engine: 2.7L V6
Axle/Gears: 4.41
I have all of the above with the exception of the rear alternator bracket (I have the aluminum one that bolts to the head). Apparently, there was something on one of the pullies making the belt squeal and it's gone now, so I have a spare tensioner assembly...
Old Apr 11, 2010 | 09:09 PM
zeb87's Avatar
Engine: 3.1 MPFI
Is there any way you can send me some pics of the brackets and do you have the top front metal alternator bracket I'm pretty sure this is a different one than the one you said you don't have. I think the one you are talking about is the bracket on the back of the alternator that bolts to the air pump? If it is than I don't need that one. Thanks again.
Old Apr 14, 2010 | 09:12 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Still have the trans and peddle and master/slave cylinder? I'm in Florida.
Old Apr 18, 2010 | 07:06 PM
G-4ce's Avatar
Car: 1989 RS
yes i still have. sry have been busy...but am getting close to junking the car
Old Apr 18, 2010 | 10:11 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I'm looking for a whole 2.8 port injected.86-89 firebird or camaro.I WANT intake and heads intack if at all possible.
Old Apr 18, 2010 | 10:12 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
not the whole car.just the motor
Old Apr 19, 2010 | 06:17 PM
84camarokid507's Avatar
Car: 84 z28 camaro
Engine: '70 355 4bolt
Transmission: TH350
Axle/Gears: 10 bolt 4.11 gears
do you have any body parts such as a front bumper sir?
Old Apr 19, 2010 | 06:22 PM
G-4ce's Avatar
Car: 1989 RS
bobby - i have intake but heads were sold. i will get pics...they were painted with engine paint
84camaro - sry but i dont have the bumper for the front
i do air conditioning so im really busy right now...sry
Old Jun 13, 2010 | 02:14 PM
Rico Sauve's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1 V-6
Transmission: 4 Speed Auto
do you still have the motor mounts that are atatched to the block?
Old Sep 12, 2010 | 12:54 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Axle/Gears: Stock round ones
i will take the intake and heater core/tb coolant assembly(metal tubes with the mounts and bolts) please please i am rebuilding now and will need in a few days to reassemble
Old Sep 12, 2010 | 02:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Don't know if he still has the parts, but I have one I'm looking to get rid of if you need it.
Old Sep 22, 2010 | 08:39 PM
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
An Intake Manifold Device Aluminum Thingy? or the Triple Bypass Spaghetti Plumbing Stuff
Old Sep 22, 2010 | 10:36 PM
  #42
Engine: 2.7L V6
Axle/Gears: 4.41
The whole pipe coming from the front of the intake (also connecting to the throttle body) running to the hose connecting to the heater core extension/bypass pipe assembly behind the alternator. And you can get the part that screws into the intake at any parts house.
Old Oct 1, 2010 | 03:09 PM
  #43
Stryder's Avatar
Car: Camaro
Engine: 2.8L MPFI
Sweet
Cleotiz
Jan 6, 2018 08:56 PM
Zane Story
Oct 8, 2015 12:40 PM
bryaniskoo
Oct 1, 2015 03:18 PM
E Rod
Aug 28, 2015 05:17 AM
SlowCamaro88SC
Sep 16, 2002 12:30 AM
