1982-1992 Reproduction Brake & Fuel Lines
Car: Iroc 88
Engine: 350 LT1
Axle/Gears: 10 Bolt 4:11
I was wondering if anyone would be interested in reproduction brake and fuel lines. I am a distributor through my work. I can make them like factory with the right fittings and the armor in the factory positions. Stainless Steel or OEM. Just seeing if anyone would be interested. I have from 3/16" all the way up to 1/2".
Thanks, John
Thanks, John
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: 1982-1992 Reproduction Brake & Fuel Lines
I guess it would all really depend on price and fitment, it would be nice to have all stainless prebent brake lines, but at what cost and what quality.
I probabaly would depending on price of course. (Stainless Brake Line). But im not sure if i need the same routings or not. Mine is a bare shell right now, and i have an LQ4 going into it. So everything in the engine compartment (fuel lines), including the mastercylender (brake lines) will be in a different location. But id be willing to bet that youd make a descent buck off this sight with that. After your name and rep gets out. Good luck! I might still contact you after the motor, and mastercylender are in to look at my options. You guys are what keeps these furums running, DO IT!
Car: Iroc 88
Engine: 350 LT1
As far as fitment, we take the orginal lines from the car and scan all the bends, then we upload the bends and have a cnc bending machine bend them to exact spec. Price's would depend on what type of line you are wanting, OEM/SS and the line itself.
Thanks, John
Thanks, John
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What's your price on stock fuel pressure and return lines for a V6? And stainless?
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
depending on price might take the 2 hardline behind the alt on tpi trans am also price line from feul filter to pump housing both oem style thnx plz PM price thnx
Car: Iroc 88
Engine: 350 LT1
Front to back 3/8" feed line is OM- $75 and SS- $110
5/16" Return line is OM-$75 and SS- $110
Car: 07 silverado daily/ 89 iroc/68 maro
Engine: 325ls/Carbed 350/none yet
Axle/Gears: stock
Wanting to know price of front to rear brake line in ss.
maybe a shipping quote to 66606
Car: Iroc 88
Engine: 350 LT1
Axle/Gears: stock
thanks were you located at
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I need some stainless front brake lines for my car and possibly some larger than stock diameter fuel lines. Can you make the small ones that go between the mastercylinder and prop valve out of SS?
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
Vintageracer
08-11-2015 08:13 PM
