Full Manual 700R4 with 3200 stall Converter
Old Mar 6, 2010 | 07:11 PM
95zedder's Avatar
Want a title? Post!
I am selling a Mag Dog Level 4 700R4 Transmission and converter. I have used it for three years and put about 6000 miles on it. Here is an insert from Mad Dogs website.
Level 4 700R4/4L60- Rated up to 800HP with converter of your choice
• All new lip seals
• All new gaskets
• All new Teflon rings
• New filter
• All new steels
• All new bushings
• All new Raybestos Clutches
• All new double-gauged sprags
• Full Competition, Reverse Pattern Valve Body
• Raybestos Z-pak
• Beast Sun Shell 3x thicker than factory
This Level 4 transmission comes with an Mad Dog Reprogramming Kit, Mad Dog shift kit, and Raybestos 15 clutch Z-pak which is top of the line and can take tons of horse power and torque (replaces factory 5 clutches in the 3-4 drum), all Raybestos high temp high energy clutches through out the rest of the unit, all new steels, band, bushings, and rings. A 500 boost valve, 10 vane pump rotor. The reason we run a 10 vane pump rotor and not a 13 vane pump rotor is because the more vanes it has in it weakens the rotor. We also use 4140 hardened pump rings. We machine a specialized bronze ring to re-enforce the hardened input shaft and drum. this is a MUST for BIG HORSE POWER Applications. Built with TEFLON pump bushing, a 29 element double-gauged sprag, 4 pinion planetary gear (which has also been cold-freezed to withstand big horsepower and torque), 3" wide high-temp Pro-Series Kevlar band, Corvette Servo/Super Sonnax 4th gear Servo and a Super heavy-duty Sun Shell. We discard the springs in the accumulators, because they constantly break and contaminate the transmission with metal filings. One, two, and three/four accumulators are blocked off to give you a nice solid shift every time.
I also ordered it with a full manual valve body and 5 pinion front and rear gearsets. It also comes with a 3200 stall torque converter that has an anti-balooning plate installed. I have paid over $2500 for the transmission and am looking for $600 for it. I am selling it beacuse I miss having a stick in the car.
Old Mar 6, 2010 | 07:20 PM
BadHabit's Avatar
Car: 1989 TPI Formula, 1984 MCSS
Re: Full Manual 700R4 with 3200 stall Converter
What part of the world are you in??
Old Mar 6, 2010 | 08:11 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
where are you located?
Old Mar 7, 2010 | 09:29 AM
95zedder's Avatar
Want a title? Post!
I live in ontario, canada about 1 hour from the buffalo,NY boarder.
Old Mar 7, 2010 | 10:31 AM
jaygt's Avatar
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
i live 1 hour from the buffalo border. i will take it lol.
Old Mar 8, 2010 | 07:49 PM
95zedder's Avatar
Want a title? Post!
Still for sale.
Old Mar 15, 2010 | 07:47 PM
95zedder's Avatar
Want a title? Post!
Sold.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Jake_92RS
Aug 17, 2015 09:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
