350 290 Hp GM MOTOR BRAND NEW
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
Going for cheap Cant ship though must be picked up i could deliver with in 50 miles though for cost of fuel brand new never turned over gm crate motor asking 1700.00 firm its brand new loss of 500.00 dollars on my end my loss your gain also have brand new edlebrock hi flo base plated 300.00 firm adds 20 hp over stock cost me 425.00 new calll Dan 516-476-7407 or email remanufactured086@hotmail.com
Part Number: 12499529
Engine Type: Chevy small-block V-8
Displacement (cu in): 350
Bore x Stroke (in): 4.00 x 3.48
Block (P/N 10066034): Cast iron with 4-bolt main caps
Crankshaft (P/N 93426651): Nodular iron
Connecting Rods (P/N 10108688): Powdered metal steel
Pistons (P/N 93422884): Cast aluminum
Camshaft Type (P/N 3896962): Hydraulic flat tappet
Camshaft Lift (in): 450 intake / .460 exhaust
Camshaft Duration (@.050 in): 222° intake / 222° exhaust
Cylinder Heads (P/N 93438648): Iron; 76cc chambers
Valve Size (in): 1.94 intake / 1.50 exhaust
Compression Ratio: 8.5:1
Rocker Arms (P/N 10089648): Stamped steel
Rocker Arm Ratio: 1.5:1
Recommended Fuel: 87 octane
Ignition Timing: Base 10° BTDC, 32° Total
Maximum Recommended rpm: 5100
Balanced: Internal
Balanced: Internal
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NinjaNife
Aug 23, 2015 11:49 AM
290, 350290, 350290hp, 3896962, 93422882, 93422884, crate, gm, motor, number, part, piston93422882, sale, supercharge, supercharged
